plans
Old Jul 7, 2008 | 07:42 PM
volcomstone411's Avatar
volcomstone411
Default plans
hi, i know there are people who know far more than me here, so im going to pick brains.
Basically, ive done everything on my car myself, and i want to carry on the same vain.
spec so far:
Racing puma fiesta -
1.7 vct zetec-se
2L rebuilt and resprung throttle body
racing puma inlet
2L zetec injectors
port and polished head
racing puma fast road cams
4-2-1 racing puma exhaust with sports cat
and racing puma catback
Run using standard loom and dreamscience to remap my own ecu, which ive done all myself and got it to 174bhp at 8000rpm.
Now ive had fabricated ready a supercharger from a mercedes slk230 which is brand new and with teflon coated blades. Its a roots type supercharger with the electromagnetic clutch system.
Simply put, i was going to ask whether its advisable to lower the compression or not, as the current compression n/a is 10,3:1.
And whether i should do that with pistons or a spacer plate. And if i get pistons, is it a good idea to get to get rods as well. Reason i ask is that the focus st170 powerworks roots type supercharger kit doesnt change compression at all?
hope someone can help
Old Jul 8, 2008 | 05:40 AM
Depends how much boost you want ?
Also depends on how strong the internals are as to whether you need rods as no idea about this engine.
Would be best to speak to someone like pumabuild etc.
Old Jul 8, 2008 | 04:37 PM
volcomstone411
do i have to, id rather than talk to them, if they arnt getting the work they arnt interested.
Well its nikisil lined so im sure the shells are about upto it as they are ganna be. Definately want low boost at this time, as its new to the engine lower boost means i can gradually increase the boost.
Ive had made a pressure plate held with springs and screws so the pressure can be adjusted.
tankybaby66
Feb 6, 2016 02:24 PM
Mc5506
Oct 5, 2015 09:57 PM
Oranoco
12
Oct 2, 2015 02:18 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
SMILER258
Sep 28, 2015 09:04 AM
