no fuel to injectors?
Old Jul 4, 2008 | 08:48 AM
turbozvh's Avatar
turbozvh
Default no fuel to injectors?
hello all ive got no fuel to the injectors on a erst mfi ive got plenty of fuel to the metering unit but no fuel coming through the injector lines ive changed the ecu no differance could it be the metering unit itself or the fuel computer. o and another thing do i need the k.e relay as ive noticed the relay is not there.. cheers..
Old Jul 4, 2008 | 08:50 AM
jacko's Avatar
jacko
id try a metering unit mate
Old Jul 7, 2008 | 05:50 PM
Phil2002's Avatar
Phil2002
I agree.
Old Jul 15, 2008 | 01:27 PM
turbozvh's Avatar
turbozvh
right ive just changed the metering unit and still got no fuel to the injectors ive also tried a fuel computer and ke relay of a running rs and still the same has anyone got any more ideas as ive run out of things to try
Old Jul 15, 2008 | 04:14 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Is fuel getting TO the metering unit?
If I understand how they work correctly, they're basically a distributor for fuel instead of HT electricity. If so, and if fuel is coming in, is it coming out of the metering unit, ie, are the pipes to the injectors blocked?
Old Jul 15, 2008 | 06:18 PM
Phil2002's Avatar
Phil2002
fuel pressure regulator???????
Old Jul 15, 2008 | 06:41 PM
Smartdj.'s Avatar
Smartdj.
im not taking the piss.........how much gas u got cause me and a m8 in erst broke down thought what the fuck gauge said 1/4 tank.....got it home..put a fiver in it ...it was fine
Old Jul 15, 2008 | 08:11 PM
turbozvh's Avatar
turbozvh
yeah we put 12 quids worth in it before we tried to start her lol. someone has told me its the pump not priming properly and need more fuel to prime it as its a high pressure one and its pumping air and fuel around hopefully that will do the trick
Old Jul 15, 2008 | 08:17 PM
turbozvh's Avatar
turbozvh
yeah fuel is getting to the metering unit and fuel is returning to the tank and the pipes i can blow through so i presume there fine
turbozvh's Avatar
turbozvh
tried three different ones and still the same
Old Jul 16, 2008 | 04:36 PM
cozmeister's Avatar
cozmeister
More boost Igor!
At today's prices that's about two injector pulses
Old Jul 18, 2008 | 12:17 PM
turbozvh's Avatar
turbozvh
all sorted fired her up yesterday thanks for all the advice
Old Jul 18, 2008 | 01:00 PM
Smartdj.'s Avatar
Smartdj.
what was it?
Old Jul 19, 2008 | 11:30 AM
turbozvh's Avatar
turbozvh
not enough fuel i had a 1/4 of a tank and the pump wouldn't prime i put another 7 quid in it and the pump primed and she fired up. all that time wasted changing things around and it was the fuel lol
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
cos elle
Sep 16, 2015 06:37 PM
tib2220
Sep 14, 2015 12:33 PM
