forged internals now or not!!!!!!!!!!!!!!!
Old Jul 2, 2008 | 08:00 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Default forged internals now or not!!!!!!!!!!!!!!!
after seeing the motors at croft it has spurred me on to sort the yb in my 3dr.
what i`d like to know is if i get my head ported etc,fit my t34 (rebuilt with a 360` and 48mm),rebuild engine,get some greys or seimens blacks.
is it worth getting some adjustable verniers and forged pistons and conrods now or when block is stripped down (i intend getting all parts over a period of time as i`m not loaded (who is with a cossie?)) i also intend getting a closed loop lambda sensor with a l8 ecu (hopefully sorted from M.A.D.) probably before rebuild etc,
please help as i want to do it right first time,hopefully i am on the right track but i`m sure i`ll be told otherwise if not.
TA
Old Jul 3, 2008 | 04:49 AM
If sticking with std cams I would not bother with verniers.
I would look at aftermarket ecu's and add up all the prices of a converted set up to L8 with coilpack etc, then you will see the price advantage of aftermarket, and then have the added advantage of a lot more featrures with most, as well as doing anything the L8 can do even when converted.
Old Jul 3, 2008 | 05:01 AM
R5FORD's Avatar
R5FORD
tabetha just hates the standard cossie managment
Im going T2 on my new engine
verniers can be timed but only give a slught slight advantage.. not really worth while for the cost of them.. but if your chasing big power then every litte helps
Old Jul 3, 2008 | 07:36 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The standard Mahle cast pistons are reliable to over 500bhp and so are the standard rods, so unless you're knocking on 600bhp I wouldn't be too concerned. Long-studding would be a worthwhile investment.
Old Jul 3, 2008 | 04:33 PM
LHD220Turbo's Avatar
LHD220Turbo
TA
dont waste your money on forged stuff, the standard internal will cope with 450-500bhp, thankfully from factory the YB was over engineered for the small bhp it was putting out
if your on a budget imo i wouldnt bother going for after market management
if your only using a t34, L8 and standard internals will be more than enough
Old Jul 3, 2008 | 07:13 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
cheeRS,i didnt fancy aftermarket management having been quoted for one,Ł`s yeah it was all singing dancing made the tea etc also didnt like the idea of having my loom chopped up especially as L8 can have closed loop lambda set up on it
thats good news about the standard kit as i have saved up enough to get the forged gear looks like t34`s gonna get rebuilt earlier.
what cams and head work should i aim for
gonna mainly used on 1/4 mile and weekend use
Old Jul 3, 2008 | 07:37 PM
LHD220Turbo
decide what bhp you want first then spec your engine from that; a t34 with the biggest housing (.63) is only going to give you approx 380-400, so standard head and cams can achieve this quite easily
as a guide my engine spec is
t34.55 -31 actuator
55lb blacks
rs500 cooler
standard engine & head
msd chip
and with this spec i'm expecting between 350-380bhp
Old Jul 3, 2008 | 09:41 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
ok so whats the point in cams and headwork,surely if i have a .48 exhaust on a t34 cams and head done i should get similar power only with less lag?
spec to date
t3 -31
3" mongoose
3 bar
dark greens
rs500 intercooler
k&n cone filter
running 1.7bar giving 293bhp & 300lbs torque
yours confused
sportvanman
Old Jul 4, 2008 | 12:12 AM
R5FORD's Avatar
R5FORD
what power do you want to acheive?
Old Jul 4, 2008 | 06:26 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
am hoping for around 420 with decent torque,
have just got hold of some greys so ball is rolling
Old Jul 4, 2008 | 07:10 AM
R5FORD's Avatar
R5FORD
you will need your head porting not esential but wise.. and everything else should be fine.. it all depends how deep your pockets are..
im having a engine built to 450-460bhp.. with low comp pistons. polished n ported head etc
Old Jul 4, 2008 | 11:45 AM
LHD220Turbo
a t34.48 wont make 420bhp in my opinion
Old Jul 4, 2008 | 12:09 PM
lamb chops's Avatar
lamb chops
i agree t34 even with a .63 would struggle to make that power.
send it off to universal turbos and have it made in to a T38 then you can make that power no probs
Old Jul 4, 2008 | 05:04 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
got a number for them please
Old Jul 4, 2008 | 05:11 PM
lamb chops's Avatar
lamb chops
try there website
http://www.universal-turbos.com/pturbos.htm
Old Jul 4, 2008 | 05:35 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
try there website
cheeRS top bloke,
any idea about who to do my head and advice on cams.............anyone?
Old Jul 4, 2008 | 09:50 PM
LHD220Turbo
cheeRS top bloke,
i think your slightly over complicating things here mate; a t38, set of greys or Siemens blacks, a decent chip, 3 map bar sensor, and a rs500 style cooler will make the power you want on a standard block, internals, head & cams
unless they is any specific reason why you want head work and cams? save you money, you dont need them for 420bhp
Old Jul 5, 2008 | 04:03 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
no specific reason to want head and cams just i was advised to if i wanted to use 1 t34.
if i do end up going with my t34 what realistically will i get from it,i didnt want to get to big a turbo for reasons of lag,but will i get much lag with a t38??????????????????
ta
Old Jul 5, 2008 | 07:32 PM
LHD220Turbo
ta
a t34 is the next step up from a t3, so whoever told you that you need to port the heads and change cams didnt really know what they are talking about
a t34 with the biggest exhaust housing (.63) will make around 400bhp'ish. It all comes down to how much you want to spend. a t34.63 wont be that laggy, it wont spoll up as quick as a t34.48 but you'll find a.63 will pull much harder later in the rev range compared to a .48.
dont go chasing numbers unless you want 420bhp for any particular reason; its much better to have a nice fast road engine.
Old Jul 5, 2008 | 08:24 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
cheeRS,was only going for 420 as i was told it was obtainable with a t34
i`m not interested in pub boasting figures just want to be quicker than my
mates civic type-r turbo (bloody jap tat) that he dont shut up about
are greys still a good idea then dont want to do a piston with dark greens
Old Jul 5, 2008 | 08:42 PM
LHD220Turbo
assuming your mates type-r is standard a stage 1 saff will eat that! your car as it is will eat that alive!
greens will be OK to about 380ish
greys will do 430-450ish
your car with that spec will be able to make 320-330bhp no problem, dont get too hung up on the t34.
your looking at Ł400 for a 2nd hand t34, and more money to change the chip (get a decent chip as well, such as MSD) for an extra few horses, personally i would bother
depending on where you live; you'be be better off spending Ł150+VAT for a decent set up with your current spec at MSD or MAD
Old Jul 5, 2008 | 09:07 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
i had it set up and i got 293!!!,should i go elsewhere then (he was worried with 96k on the clock turning the boost up it would go bang)
i already have the t34 (needs a rebuild though) bit of sideways play!
not wise i gather fitting it with my current spec y/n
oh his civic aint standard its got a spec as long as your arm
Old Jul 6, 2008 | 12:05 AM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
t34.55 -31 actuator
55lb blacks
rs500 cooler
msd chip
this quote is more realistic ^^^.... 420-430 requires light head work and on the limit of a T34... if not too much... for a 400-480 spec i'd say a GT30...
if your wanting 450ish i'd recommend pistons, rods, head work, oil pump, gt30 fueling to match as in pumps/injectors....
lets face it 400+ starts getting expensive run 400hp safe and just enjoy it imo...
Old Jul 6, 2008 | 12:21 AM
R5FORD's Avatar
R5FORD
for 450+ use a roller eraing t38
Old Jul 6, 2008 | 08:04 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
t34.55 -31 actuator
55lb blacks
rs500 cooler
msd chip
to be honest these figures seem great to me,again it was only cos i was
told a t34 would do 420,should i get rid of the greys and get light blues or
will a closed loop lambda sensor stop overfueling with the greys
ta
Old Jul 6, 2008 | 08:29 AM
LHD220Turbo
ta
i've heard that greys overfuel only on idle; but not sure how true that is, go for siemens blacks 83lb (2.8ohms) $244.50, that way if you do want more power later on these injectors will cope no problem.http://www.fiveomotorsport.com/Injector_SetsMODS.asp
Old Jul 6, 2008 | 03:19 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
now hows about this,at what stage do you start thinking about air
injectors and coil packs (i had a transit van with a yb in and had loads of
trouble with the plug leads etc)??(not that i am thinking bout investing in
them)
am i getting ahead of myself just that i`ve read so much about them
being great,i know if air injectors pack up then chances are you lose your
engine
Old Jul 6, 2008 | 05:09 PM
LHD220Turbo
them)
engine
your getting ahead of yourself mate, dont need them for the spec you are running
Old Jul 6, 2008 | 08:13 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
ta thought i was,i`ll get me coat.
cheeRS
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
richierich1986
Sep 18, 2015 03:29 PM
mattxr3i
Sep 13, 2015 05:52 PM
