Car juddering
Old Jun 26, 2008 | 05:47 PM
andymkfour's Avatar
andymkfour
Default Car juddering
mk4 escort xr3i efi, Pulling away in first, and in reverse the car judders really bad, shakes everything about, once it gets over about 2000 rpm, it drives fine, it has started to do it in 2nd now too, Im thinking the clutch, or the thrust bearing, someone else told me engine mounts, ive changed two of the mounts and its still as bad, its getting so bad i cant even drive it!! any answers would be appreciated
Old Jun 26, 2008 | 05:51 PM
micxr3i's Avatar
micxr3i
i had is problem in my mk4 3i and i changed everything then someone said to change the fuel relay under the dash in drivers side footwell and since then not had a problem with it hope this helps
mic.
Old Jun 26, 2008 | 06:34 PM
andymkfour's Avatar
andymkfour
Default .
is that the grey one?
Old Jun 26, 2008 | 06:45 PM
BigErn's Avatar
BigErn
Is it a speed related problem? Does it judder doing the same speed no matter what gear you are in or is it just the gears you have mentioned?
Old Jun 26, 2008 | 06:52 PM
andymkfour's Avatar
andymkfour
Default .
Once i pull away the car is great, no performance lost its only when i have to pull away from a stationary position, tried it in second and does it still
dannyb's Avatar
dannyb
Mine judders is in first and reverse and mine is definatly the clutch, it all at the bottom of the pedal and is more like a on/off switch, and the release bearing is whining its tits off if you have any similar probs
Old Jun 26, 2008 | 06:59 PM
andymkfour's Avatar
andymkfour
when driving it is quite hard to get into gear sometimes, doesnt crunch in, just needs a bit of force
Old Jun 26, 2008 | 07:06 PM
BigErn's Avatar
BigErn
Does it only judder while your slipping the clutch to pull away or is it still happening with the clutch fully out just moving slowly?
Old Jun 26, 2008 | 07:09 PM
andymkfour's Avatar
andymkfour
Default .
Fully out after i get past about 10mph its all smooth, its violently juddering too, i jacked the front end up and the wheels move freely, tried that coz i thought maybe the brakes were locking on or disc warped but moves freely
Old Jun 27, 2008 | 05:54 PM
andymkfour's Avatar
andymkfour
got the problem sorted out today cost me over £200 ended up being the previous owned has smothered the shaft with copper grese making the thrust bearing to slip and burnt the plate out, and scored the fly wheel! car drives sweet as anything now! thanks for all your help!
Shows & Track Days
Aug 26, 2015 05:11 AM
mattman1234
15
Aug 14, 2015 10:05 PM
Archiejay
Aug 12, 2015 12:07 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
