fiesta knocking sound problem
Old Jun 15, 2008 | 07:50 PM
Lozzy08's Avatar
Lozzy08
Exclamation fiesta knocking sound problem
Hi, my fiesta ran out of oil the over day and started knocking. The damage has been done so please dont bother telling me im an idiot for letting it run so low but the point is me and my friend who's a mechanic have took the sump off to try and figure it out and we have found bits of metal in the bottom. Some of the metal bits are rounded and others are just little bits. Could it be a bearing as we think it may well be this. Also the metal bits havent been pumped around the engine due to the oil pump having a filter gauze. If it is from the top end and has scored the cyclider/piston, how much would it cost to get the engine bored? thanks alot guys n gals
Old Jun 16, 2008 | 05:23 AM
It is most likely the top surface of the big end bearings that are in the bottom as these are generally first to go.
Old Jun 16, 2008 | 06:21 PM
Lozzy08's Avatar
Lozzy08
thanks for yur input, we took the engine apart today and found it was the big end bearing on piston no.1 it was completely wrecked so were going to replace all the bearings and put new piston rings on as it burn oil a bit. thanks for the advice
JoeyBoyden
Jan 4, 2024 02:36 PM
Ben26
Aug 27, 2015 08:56 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
muz
Aug 1, 2015 06:48 AM
