t34 or gt30
Old Jun 15, 2008 | 11:22 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
Default t34 or gt30
ow do folks,have got hold of t34 with a 48mm exhaust housing it has a little sideways play in the shaft,i have just had my 3dr dynoed (293 bhp with 300 lbs torque(1-31,greens,rs500 `cooler,mongoose,3bar)) not bad i thought for 96k on the clock,i was advised by the operator to sell my t34 and buy a gt30 instead,i think i will struggle to get an exhaust to fit my yb.
was just wondering if i was better off getting my t34 rebuilt or the gt30 (he said it will spool up quicker and hold the boost better) and who you would reccommend localish to rebuild the t34 if possible ( i`m in north yorkshire)
cheeRS
Old Jun 15, 2008 | 02:00 PM
LHD220Turbo's Avatar
LHD220Turbo
cheeRS
stick with the t34 for that spec, i would have thought gt30 was overkill
Old Jun 15, 2008 | 02:04 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
You would need more than just a GT30...
You'd be getting into new injectors, at least 1 camshaft, a head gasket and a mapping session...
A GT30 is a 450+bhp turbo.
For what it'd cost to upgrade compared to what it'd cost for a turbo rebuild - to me it's a no brainer if you're happy with the way your car drives at the moment!
Old Jun 15, 2008 | 05:49 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
oh yes i understand i need more than a gt30 for serious power,i fully intend to get all i need for the next step,if i were to keep it on a t34 what would its limit be bearing in mind it is 48mm ,i dont want it too laggy.
as stated i am saving up for the forged internals for the rebuild that the old girl will need.as far as cams go am i right thinking bd10 and bd14??
Old Jun 15, 2008 | 05:54 PM
LHD220Turbo
depending on what the rest of you spec is, a t34.48 will go to around 350bhp ish, .55 - 360-370 and .63 370-400 ish
what head work are you having done?, a well ported head will make the world of difference
Old Jun 15, 2008 | 06:22 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
not 2 turbos i would compare..............u need to sort out ur spec and future power level..............
Old Jun 15, 2008 | 07:05 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
as far as headwork is concerned thats my wifes domain!!
but seriousley i was thinking of sorting the head while the engine is rebuilt are we talking gas flowing,port match etc? who is best to see about this?
cheeRS
Old Jun 16, 2008 | 05:27 AM
The TURBOCENTRE near LEEDS are the boys near you, 01924 404112, ask for Andy or Craig.
A T34 with .48 will piss 420 all day long.
Old Jun 16, 2008 | 05:34 AM
coachworz's Avatar
coachworz
will ported head , T34 .63and cams makes 450?
Old Jun 16, 2008 | 05:20 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
420 sounds a nice round number to me what injectors and head work will i need? is their anyone near me that can do the head?
Old Jun 16, 2008 | 05:34 PM
LHD220Turbo
siemens black 83lb or greys, CNC heads i've heard good things about but me personally havent had me head ported, i'm sure someone will reply with recommendations
Old Jun 16, 2008 | 05:39 PM
Staffi's Avatar
Staffi
450 on a T34, Errrr, no fella..................
Old Jun 17, 2008 | 01:18 PM
coachworz's Avatar
coachworz
so 420 is the max on a t34?
Old Jun 17, 2008 | 01:49 PM
Staffi's Avatar
Staffi
I'd say yeah, people have had them Dyno'd with a little more, but it's busting it's guts out...
Old Jun 19, 2008 | 08:58 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
cheeRS fellas will get hold of turbocentre this week,what cams should i be looking at getting and presume turbo guys will need to know my intentions regards cams and head????
to me
Old Jun 19, 2008 | 09:01 PM
LHD220Turbo
to me
depends on what power you want; your better off deciding what bhp you want first
what do you intend to use the car for? road?, track?, 1/4 miles? decide on how you want the car to drive then decide the spec from there mate
Old Jun 20, 2008 | 01:23 PM
Yura's Avatar
Yura
power at wheels? what boost do you run(hold, peak)? mongoose full 3"?
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
Rsmat
63
Sep 25, 2015 12:11 PM
