What Causes Boost Spike
Old Jun 2, 2008 | 11:46 AM
STUCOS's Avatar
STUCOS
Default What Causes Boost Spike
On my 2wd saff the boost is set at approx 14 psi,but when i give it a hard time,my secs monitor flags up an over boost alarm and shows a peak of 26 psi,any body any idea,s
cheeRS stu
Old Jun 2, 2008 | 12:24 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
you are overboosting your engine by 12psi? what gear(s) does it do that in?
Old Jun 2, 2008 | 12:26 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
That is the trouble with an electronic gauges, they will capture the briefest of spike. Even if it is too short (fractions of a second) to actually register on an analogue gauge. Providing that you are not seeing this register on your normal gauge, then don't worry about it .
However, if this is what your SECS is continuously seeing, then make sure that the hose hasn't popped off your actuator giving unlimited boost .
Build the boost progressively in a tall gear from low rpm and report back what it is climbing to and at what revs. If it starts to climb above 14psi - BACK OFF. Take it to your tuner for a thorough check over. I would also point out that some NMS ("Gunship") stage 1 conversions have been live-mapped to run this kind of boost in the mid-range, so it isn't always an issue, but I would get it checked out before you lunch an engine....
Old Jun 2, 2008 | 12:28 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
What boost control do you run?
How long does this spike last?
Old Jun 2, 2008 | 12:57 PM
STUCOS's Avatar
STUCOS
Guy,s l1 ecu ,pj stage one chip, forge actuator,normal driving it doesnt do it,no manual boost guage
cheeRS stu
Old Jun 2, 2008 | 01:02 PM
Chip's Avatar
Chip
And how long does the spike last?
Old Jun 2, 2008 | 01:03 PM
STUCOS's Avatar
STUCOS
Dont know chip,as monitor flashes till you reset it,but would say a slit second,as you dont feel 26 psi of boost
Old Jun 2, 2008 | 01:07 PM
Chip's Avatar
Chip
Well then ignore it, its just what the map sensor sees for an instant while the actuator is responding to the boost by opening the wastegate.
Really the monitor should have a setting to decide how long a boost condition needs t be met for before it alarms.
Old Jun 2, 2008 | 01:11 PM
STUCOS's Avatar
STUCOS
Best thing to do is switch the alarm off then
cheeRS stu
Old Jun 2, 2008 | 01:13 PM
Mike Rainbird
Caraholic
I would want a manual gauge in to confirm that the boost spike is not lasting.
You said it doesn't happen in normal driving - what do you have to do to induce it?
Old Jun 2, 2008 | 01:17 PM
STUCOS's Avatar
STUCOS
Drive normal mike and it,s ok,quick blast with full throttle in 2nd,3rd and 4th gear,look across and alarm showing on monitor,when we fitted chip,we set boost up with manual guage,maybe have to fit it full time
cheeRS stu
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
