HP oil pressure...?
Old May 18, 2008 | 07:24 PM
2wd's Avatar
2wd
Default HP oil pressure...?
I am Just about to put in a HP Cosworth oil pump in my 2wd Sapp. Cosworth, and I actually dont know what pressure to expect...cold and warm ???
Old May 18, 2008 | 07:45 PM
ickey818's Avatar
ickey818
Just fitted one of the new Cosworth billet style HP oil pumps to my 4x4 cossie, I know it's not a 2wd but hopefully will give you some idea.
I get 75-80 psi pressure from cold, 25-30 psi pressure at idle when warm and 60-65 psi when driving. I'm using 10W50 Silkolene Pro S oil.
Hope this helps
Old May 18, 2008 | 08:13 PM
rapidcossie's Avatar
rapidcossie
Hope this helps
pretty similar to what I have on my new pump too.
Old May 18, 2008 | 10:16 PM
2wd's Avatar
2wd
hmmm....ok...I run a 10-50 oil too, but when I fired it up first time it went to around 98-100 lb"....(I think it's the same as psi...but not sure)... on my incar gauge...??
Old May 19, 2008 | 04:09 AM
lb" = POUND(per) SQUARE INCH / PSI so is the same.
I started my dads car up yesterday to move it a xr4i with V8 rover engine, 20PSI COLD, and that is GOOD for one of these, it drops off the scale when warm!!
Old May 19, 2008 | 12:45 PM
2wd's Avatar
2wd
hmm..20psi...that was low...
it's just that I was not expecting pressure to be around 100psi from cold...but I will try to let the engine get warm and see if it drops...hopefully...
Old May 19, 2008 | 02:40 PM
The rover V8 is a high volume, low pressure oil supply engine, 35/40psi when warm at 3000revs.
NOT to be confused with COSSIE oil pressure, I was just saying that it(cossie) is not low compared to some.
The figures given by people above is what I would expect from a cossie engine, I'd not be worried if mine had 20psi@idle so long as it picked up on the move.
Old May 21, 2008 | 10:16 PM
2wd's Avatar
2wd
Just got the car out for a spin...and it shows around 35psi at idle when warm... .. so I take that it's ok .. ?
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
