fitting a t3 to a frst.....
Old Mar 21, 2008 | 05:55 PM
ShandzS1's Avatar
ShandzS1
Default fitting a t3 to a frst.....
Whats all involved? erst manifold + turbo?
Old Mar 21, 2008 | 06:23 PM
Phil2002's Avatar
Phil2002
You need the exhaust manifold, turbo and down pipe from an escort that about it i think. you may need to modify your exhaust to fit the erst down pipe.
Old Mar 21, 2008 | 10:43 PM
rapidonion's Avatar
rapidonion
Smile t3
you need erst t3 and manifold also the down pipe, then you need a t3 oil feed hose as for the drain you will need to prise yours out of the block and pop in a stub from an erst or have one made its 16mm by the way appart from the bottom charge hose from the t3 turbo its happy days do it the t2 is shit.
a thing to consider also is having the correct chip flashed as the fueling is way off from the t2 i had one done and it now pulls fine wereas before i found it slower even with the bigger turbo
Old Mar 26, 2008 | 12:02 AM
ShandzS1's Avatar
ShandzS1
Cheers!!!!!!
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
