Zetec turbo injectors?
Old Feb 26, 2008 | 08:33 PM
slammedorion's Avatar
slammedorion
Wink Zetec turbo injectors?
What injectors can I use for a 2 litre zetec turbo build?
Hoping to use standard inlet maifold to start off with... aiming for 250bhp build to begin with... in a MK2 Orion...
I'd like to use 2nd hand parts to keep cost down, but info on old or new greatly appreciated...
Heard 200sx injectors fit...?
Anything else out there that might do the trick...?
I've got a set of 380cc Impreza injectors spare lol, dunno if they'll fit...?
Old Feb 27, 2008 | 04:20 AM
Mr.T's Avatar
Mr.T
Think using a cvh inlet or change the std inlet to fit topfeed ones. Then there is no problem for you to find the spec injectors you want.
Old Feb 27, 2008 | 06:35 AM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
standard inlet (if its metal) xr2i/frst injector rail with frst or cpssie injectors
Old Feb 27, 2008 | 04:22 PM
slammedorion
Talking
Hmmmmm, cheers... anymore options out there...
Ta for the replies...
Old Mar 10, 2008 | 12:07 PM
mariS's Avatar
mariS
Im building mk4 Escort and Ill build Zetec 1,8 16v Turbo with megasquirt and Ill try to use Nissan 200SX 370ccm injectors. Ill go to 200bhp so the Nissans injectors will be good. But Im not sure with the rail, inlet etc. I would like to use mk4 XR3 inlet like Christian and Beccy on their Escort. But maybe Ill have to use standard Zetec inlet.
Old Mar 15, 2008 | 10:48 PM
disc's Avatar
disc
Check here:
http://www.fiestaturbo.com/forums/ze...7b064fd1184cb5
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
