Whining from front wheel?
Old Jan 26, 2004 | 10:27 AM
Spinza's Avatar
Spinza
Default Whining from front wheel?
I have this whining sound that has just developed from my front wheel, dunno which one (think drivers). It only happens when the car is coasting (not under acceleration) and over 30mph.
Also the PAS seems to be stiffer than normal, could these be related??
CheeRS
Old Jan 26, 2004 | 12:30 PM
yogi's Avatar
yogi
sounds like a wheel bearing as you say when coasting say 30mph all the wait ison the front but when you put your foot down the front of the car lifts up less weight on front
Old Jan 26, 2004 | 06:07 PM
Spinza's Avatar
Spinza
The whining is not continuous and i thought if it was bearing the noise would be constant?? the whining is in pulses if that makes sense
Old Jan 26, 2004 | 08:14 PM
Fozy's Avatar
Fozy
its not you alternator belt is it? Might be slipping hence why the power steering could be heavy.
Although doesn't explain why it does it when its coasting.
Could be an wheel bearing or at worse a diff/gearbox bearing which i doubt.
Chas
Sep 21, 2015 08:57 PM
borboyous
Aug 22, 2015 11:17 AM
C2 MAK
Aug 20, 2015 09:46 PM
mattman1234
15
Aug 14, 2015 10:05 PM
muz
Aug 1, 2015 06:48 AM
