heater problems
Old Dec 11, 2007 | 08:43 PM
lynnstillie's Avatar
lynnstillie
Default heater problems
just bought a cossie and heaters were very cold so i bought a new thermostat when i took the housing off i noticed that there was no thermo in it put one in and i got heaters very hot when standing still but im losing heat when car is driving the water is comming back into the header tank no problem so i dont think there is a blockage anyone got any help .......the guy i bought it off said he just had the head gasket done with a new timming belt i can see there has been a new timming belt and new pulleys but cant see if theres a new head gasket done please help
Old Dec 12, 2007 | 12:40 PM
lukemakepeace's Avatar
lukemakepeace
your probably losing the heat when your driving as the cold air is flowing through your radiator and doing its job - cooling the water down, therefore if the water is colder your heaters will blow colder. nothing to worry over.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
