1.6 zetec. someone help
Old Dec 10, 2007 | 09:00 PM
lukemakepeace's Avatar
lukemakepeace
Default 1.6 zetec. someone help
on my mk6 escort. (1.6 zetec) i ws driving it around, i think its the first time for a week and anyway it was making a whooo whooo noise so i pulled over to see if a back window was open.
when i pulled over the revs started going from 500 to 1500 RPM up and down about 6 times so i revved the engine to abut 4000 RPM held it there for about 3 seconds and let off then it was fine..........
can anyone tell me why it did this?
thanks for help
Old Dec 10, 2007 | 09:04 PM
phil_focus's Avatar
phil_focus
hmm, odd! was it hunting quickly or was it more rising gently and falling gently?
also, if it not been used for a week an doesnt get driven hard then go an rag the tits off it up the motorway. blow away the cobwebs
Old Dec 10, 2007 | 09:13 PM
lukemakepeace
was quite fast hunting.
Old Dec 10, 2007 | 09:19 PM
Wardy257's Avatar
Wardy257
Check and clean the ISCV.
Old Dec 10, 2007 | 09:22 PM
ShandzS1's Avatar
ShandzS1
same as above
Old Dec 10, 2007 | 09:37 PM
phil_focus's Avatar
phil_focus
if thrashing it doesnt cure it then it does look like the iscv.
also check the pcv house round the back of the engine that attaches onto the inlet manifold. it can colapse and cause an air leak which may be intermittent.
Old Dec 10, 2007 | 09:38 PM
lukemakepeace
how do i clean the iscv
Old Dec 10, 2007 | 10:26 PM
phil_focus's Avatar
phil_focus
undo the 2 8mm bolts and disconect from the loom. fidally!
then tap out an crap thats in there, spray with wd40, some people have also soaked it in wd40 for half hour to get all the dirt out. then leave to dry and re-fit, also fidally
Old Dec 10, 2007 | 10:56 PM
lukemakepeace
oh ok, easy thanks, erm where is it lol
is it the bit that is on the inlet manifold?
mondeomark
Sep 28, 2015 06:28 AM
sridgett
13
Sep 27, 2015 06:03 PM
liamT74
Sep 23, 2015 10:24 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
