Sheared head bolt!
Old Oct 9, 2004 | 06:46 PM
mkv_turbo's Avatar
mkv_turbo
Default Sheared head bolt!
Hi peeps
ive got a bit of a problem in the shape of a sheared head bolt
any ideas ppl, tried mole grips & a pipe wrench so far
Nath
Old Oct 9, 2004 | 07:06 PM
abdr500's Avatar
abdr500
you could get a hammer and flat head and hit the edge and it should turn ant clock wise if not use a angel grinder and cut a grove in the midil of the stud and turn it with a flat head screwdriver or hit it once in the grove
Old Oct 9, 2004 | 07:17 PM
mkv_turbo's Avatar
mkv_turbo
dont really fancy putting a hammer near the block face
Old Oct 9, 2004 | 07:24 PM
CosRush's Avatar
CosRush
If your careful, using a hacksaw cut a screw driver slot in the top, and use a decent large head screwdriver with a socket body (the ones where you can use a spanner on it).
The apply loads of downward pressure by leaning on the screwdriver head and with the spanner on the screwdriver body turn the screwdriver.
Would be an idea to spary some wd40 or similar on it first ensuring it seeps down any minute gap around the bolt.
Plus, to be safe, get a scrap piece of sheet aluminium (small piece) and drill a hole the same size as the top of the bolt. then place this over the bolt head and should you slip off with the screwdriver you'll hit the sheet metal and not the block.
hth
Old Oct 9, 2004 | 09:48 PM
Chris Honeywell's Avatar
Chris Honeywell
hth
spot on advice m8 that should sort it
Old Oct 10, 2004 | 04:44 PM
mkv_turbo's Avatar
mkv_turbo
will have to wait til next weekend now, hopefully it'll come out
cheers ppl
Old Oct 11, 2004 | 10:51 AM
Dave Henshall's Avatar
Dave Henshall
or geta set of the draper roller bearing stud extractors, no damage to the head and they do just grip and the harder u turn, the harder they grip, they are about 20 quid for th set from most motorfactor or tool places.
Old Oct 11, 2004 | 02:12 PM
CosRush's Avatar
CosRush
Let us know how you get on...
There are some other methods if none of these work...
Old Oct 11, 2004 | 08:04 PM
spannerman69's Avatar
spannerman69
if you can run to it snapon do external extractors about 25 quid each .they come in all the diffrent sizes the part number you need is bexw and the bolt head size .ie bexw 15 and so on .they fit over the outside of the bolt and are taperd so the more force you put on it the better it grips .saved me loads of time and money.
Old Oct 11, 2004 | 09:48 PM
Mr.h.'s Avatar
Mr.h.
May sound a bit savage but could u just not spot weld a nut 2 the top of it???
Im a roofer and not very mechanicly minded so sorry if thats not what should b done near the head
Old Oct 12, 2004 | 03:42 AM
djskitzy's Avatar
djskitzy
These work, they've saved me a few times
Old Oct 12, 2004 | 03:47 PM
Andymancos's Avatar
Andymancos
Ive done this works everytime
Old Oct 14, 2004 | 02:54 PM
jayRS's Avatar
jayRS
when it happened to me i welded a nut on ( cover the rest of the block with something splatter cant burn throught thick cardboard should do) had been blasting it with anti seeze oil for a while before hand too.
once you get it moving undo then do up a tiny bit spray some anti seeze in and carry on like this , job done mate, dont be to heavy handed or your in the shit, take your time.
as for extractors, being a engineer these do work but if they snap 9 and a lot do your fucked if you can get the bit out.
look at it this way, it you could undo it when it was soild how much chance do you stand with a extractor? not to say it wont work, i just would waste my time with them, not on a head bolt
Old Oct 14, 2004 | 02:56 PM
jayRS's Avatar
jayRS
forgeting my T's al the time should be cant and couldn't doh
Old Oct 16, 2004 | 01:02 PM
mkv_turbo's Avatar
mkv_turbo
cheers for the advice ppl
ive decided to take the easy option, my mates uncle is a mechanic, hes gonna sort it for me. should've done it in the first place would've saved me abit in tools
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
IainRS1700T
Sep 25, 2015 06:44 AM
focuspower
Sep 19, 2015 08:27 PM
hopper350
Sep 4, 2015 12:53 AM
