minimum YB head thickness????
Old Nov 21, 2007 | 09:33 AM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Default minimum YB head thickness????
Anyone know? Cant find it anywhere
Old Nov 21, 2007 | 10:47 AM
Toe Knee's Avatar
Toe Knee
138.68mm althou obviously can be compensated for by running a thicker head gasket or skimming the pistons
Old Nov 21, 2007 | 11:28 AM
Daveysaff's Avatar
Daveysaff
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=019
Is this scrap then?
Old Nov 21, 2007 | 12:18 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
where did you get that gem from then?
ive used them down to 137.7 with no problems.
Old Nov 21, 2007 | 04:13 PM
Daveysaff's Avatar
Daveysaff
Thank god for that
Mines 138.65mm and for sale
Old Nov 24, 2007 | 03:11 PM
Toe Knee's Avatar
Toe Knee
Its what stu and other engine builders have posted up in the past to be the miminum 'reccomended' thickness as i asked and other ppl have asked in the past, obviously people have run less than that and do run less with no problems not saying its gospel and ur engine will blow up if its less than that am i but obviously when its gets that low its getting close to the valve seats as well and like i say if u run low comp or adjust the piston height etc it can compensate
Old Nov 24, 2007 | 03:20 PM
Micky The Finn
Former Sponsor
but on stu's post he said 138.4mm,and then a hole huge debate went on and it was shown time and time again how heads thinner than this were working fine with no troubles at all.
Old Nov 24, 2007 | 03:43 PM
Toe Knee's Avatar
Toe Knee
and again would it not stand to reason that it would depend on the spec of the engine that the head was on?! like i said things can be adjusted to compensate and as long as clearanaces are checked then it isnt a problem is it. Must have missed that post then as it was a long time ago i asked and that was what i was told by a few people.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
