RE-SHELL
Old Nov 20, 2007 | 03:01 PM
ROB3RT's Avatar
ROB3RT
Default RE-SHELL
HELLO THERE AM CURENTLY THINKING ABOUT RESHELLING MY XR2I I HAVE A MINT SHELL LINED UP I JUST NEED A ROUGH IDEA OF THE PARTS I NEED TO KEEP AND WHAT CAM BE SCRAPPED WITH THE SHELL
THE BIT THAT I AM MOST AFFRAID OF IS THE WIRING . I WOULD ALSO LIKE TO NO IF THERE ARE ANY DIFFERENCES BETWEEN A 1.3 LX SHELL AND MY CURRENT ROTTEN XR2I SHELL ?
ALL HELP WOULD BE APPRECIATED THANKS
Old Nov 20, 2007 | 07:11 PM
St3V3_C's Avatar
St3V3_C
Can't really help sorry, but I hope you are not hoping to call it an XR2i after this work?
Old Nov 21, 2007 | 12:35 AM
antony215's Avatar
antony215
Escort Rs Turbo
Everything will fit so save as much as you can the shells are the same iirc. As above you do know that it will lose it's xr2i id so it will be just a 1.6 LX on the log book (if you inform DVLA of the changes) as you can not swop the id from car to car in some case's it will need to be looked over by DVLA then will be put on a Q plate
http://www.direct.gov.uk/en/Motoring...le/DG_10014246
Old Nov 21, 2007 | 04:51 PM
derekg7156's Avatar
derekg7156
you should need to keep everything untill you have finnished, its a pain in the arse if you dump bits then need them a week later
Old Nov 22, 2007 | 04:35 PM
ROB3RT's Avatar
ROB3RT
cheers everybody
and dont worry i wont [pass it of as somthing its not
SillyFezzaMk1
May 4, 2009 09:28 AM
Cosmo
13
Mar 30, 2008 06:10 PM
sheps
Jun 5, 2007 11:17 PM
fordsportjay
30
Apr 5, 2006 02:59 PM
