ignition timing
Old Nov 7, 2007 | 09:03 PM
purplemonster's Avatar
purplemonster
RWD PUMA :)
Default ignition timing
hi can some one tell me how to adjust my ignition timing on my 2wd cosworth
thanks
Old Nov 7, 2007 | 09:41 PM
mechanic28's Avatar
mechanic28
u dont chap it part of the ecu control why u ask??
Old Nov 8, 2007 | 07:02 AM
JesseT's Avatar
JesseT
You can do it the brutal way by moving the crank sensor but there is no built in adjustment for it. As said above the intended way to adjsuting the advance is by making a new chip.
Old Nov 8, 2007 | 08:30 PM
purplemonster
RWD PUMA :)
i have just built a new engine ,and got a poor idle with erratic idle
but the engine is bits and peices from everywhere maybe just needs a set up?
its a 2wd with greys 3 bar and chipped t34 and rs500 intercooler
ill just put some miles on it then book a rolling road sestion
Old Nov 8, 2007 | 09:27 PM
mechanic28's Avatar
mechanic28
what part of the uk u from ??
Old Nov 10, 2007 | 10:24 AM
Stu @ M Developments's Avatar
PassionFords Creator
As said, its ECU controlled. Look for reasons your ecu may make the wrong decisions instead, such as sensor error.
You have i presume set the CO since you rebuilt her?: ?
Old Nov 10, 2007 | 01:20 PM
JjCoDeX75's Avatar
JjCoDeX75
Also based on my own experience I would be thinking about making sure the FPR was working correctly and set up properly
JJ
Old Nov 11, 2007 | 08:10 PM
purplemonster
RWD PUMA :)
thanks for the replies
i have not done either as yet ,set the co or the fuel pressure
i can check and adjust the co @ the mot on thursday but the fuel pressure i cant do unless i can make a tool up ,and i know that needs doing before the co anyways
thanks guys
it will be off to the rolling road for a setup as soon as i can anyway which should sort alot of it out
my ecu is chipped and i have 3bar and greys with rs 500 intercooler
so apart from a few adjustments what else can the rolling road man do if my ecu has allready been setup before hand
Old Nov 11, 2007 | 10:01 PM
purplemonster
RWD PUMA :)
as far as i know the ecu and all the bits came with then engine
so as far as i know yes
on the chip its states t34/803/3bar,and thats whats on the engine
Old Nov 11, 2007 | 10:50 PM
jon@work's Avatar
jon@work
803s are greens, not greys
Old Nov 12, 2007 | 05:06 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Hence why it's running like poo , The ECU will be putting too much fuel in as it thinks it is running smaller injectors than it is. Either change the chip for one that runs greys/403's or put in green 803 injectors
Old Nov 12, 2007 | 09:36 PM
mechanic28's Avatar
mechanic28
bore wash time chap get the right chip asap
van_dogg_pavvy
Mar 3, 2016 09:30 AM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
