cossie 4x4 running on 3 cylinders
just sum advice if anyone could help, my car has been dry stored for the last 6 months, but i do go and start it up every month, lately tho its been running on 3 cylinders. then somtimes it will be fine again. any help would be appritiated, thanks in advance, shaun..
Received 1,044 Likes
I would check ur spark plugs 2 start off with. Then i would take them out and stick them in the spark plug leads 1 at a time n crank the car 2 make sure they r sparking then put the plugs in each spark plug lead n make sure there all ok. If you can get hold of a compression tester and check your compression in your cylinders. You can also buy little node lights that go into your fuel injector connectors 2 make sure the ecu is working.
IF it's been ok till now I'd suggest one of the spark plugs has given up due to being flooded by the fact you keep starting it up and not driving it!
new plugs job done
ps it could also be stale petrol but I doubt it's that
new plugs job done
Re: cossie 4x4 running on 3 cyliders
Originally Posted by bigcam
iv tried new plugs and leads and it still runs on 3 cyliders, but like i said b4 its ok sumtimes. got me puzzled ?
then it's possible a sticking valve/valves on that cylinder(once you start using it again then it should rectify itself)!
You could then try some engine cleaner in the oil, I use WYNN's to fantastic effect, every oil change, not a speck of black anywhere, was gunged to hell when I got the car.
ekjim
17-08-2015 08:57 PM
Zoggon
10-08-2015 10:39 AM
Red_bull
09-08-2015 08:34 AM
