whats wrong with my brakes??
Old Aug 21, 2007 | 01:34 PM
<____ALEX____>'s Avatar
<____ALEX____>
Default whats wrong with my brakes??
hi people.
i have just recently upgraded my disks,pads and changed the fluid to dot 5.1 on my orion. I now discover that if i push the brake pedal slowly it will go all the way to the floor and them bit allitle bit but then if i bake sharp it works fine??? could it just be air in the system or could it be my sevo?
any ideas??
thanks
Old Aug 21, 2007 | 01:36 PM
Aaroncast's Avatar
Aaroncast
AND THE CAR IS A ??????????????????
Old Aug 21, 2007 | 04:22 PM
I think it is an ORION, as it says so, your as bad as me!!
Sounds like the m'cyl seals may be weak.
Old Aug 21, 2007 | 04:24 PM
<____ALEX____>
1989 1.6i ORION
Old Aug 21, 2007 | 05:29 PM
mechanic28's Avatar
mechanic28
give your brakes 500 miles to bed in
Old Aug 21, 2007 | 05:30 PM
I wud say there is air in the system if u pump the brake pedal a few times does the pedal go hard. Then push the pedal again n if it goes 2 the floor i wud of said it has air in the system.
Old Aug 22, 2007 | 11:19 AM
<____ALEX____>
yer thats pretty much exactly what it dose,it dose it most when say im comming upto a junction or summin and i press it lightly it will just sink to the floor so i will have to take my foot off it and press it hard n then it will work. i gunna bleed them again tonight,do you know if there are any other bleed nipples other than the ones on the calipers?
thanks
Old Aug 22, 2007 | 07:28 PM
Moondust_crust's Avatar
Moondust_crust
will be air in the system mate, make sure you hold the pedal down then do the bleed nipple up , id give it a few goes with a bleeder, hth, cheers mark.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
