Best Way To Turbo A 16V Zetec Engine?
Old Aug 12, 2007 | 09:13 PM
McGoo 69's Avatar
McGoo 69
Default Best Way To Turbo A 16V Zetec Engine?
Right this is something i realy want to do.
Ive read alot of things about turbo'ing a zetec engine but which is the best and most efficiant way to do it at home?
What guides are about to help me do this? ive seen a few on ebay where you pay to get the info put what are they like?
Ive also found this on the internet what has alot of information on how to do it but no pictures to help me along the way what will be realy helpful.
http://turbo.me.uk/?p=home
Im no machanic ive rebuilt many motorbike engines and i have rebuilt the top end of a zetec before but i have never done anything as big as fitting a whole turbo system and everything else what is needed for it to work, new exhaust manifolds etc.
It wont be a rushed project its something i want to do to my engine.
This is the spec of my engine i already have:
FIESTA RS1800i ,ESCORT MK5 GEARBOX CASING WITH CUSTOM GEARBOX BUILD WITH ESCORT RS1600i INTERNALS, PORTED AND POLISHED GAS FLOWED HEAD,2.0L INLET MANIFOLD,UNICHIP,K&N AIR FILTER,CUSTOM STAINLESS ESCORT COSWORTH STRAIGHT THROUGH EXHAUST (CANT REMEBER REST,WILL FIND OUT) ITS PUSHING OUT 165BHP ATM
oops caps
is this a good base or should i start from scratch?
Any help would be much appriciated as i want to do alot of research before i even take the engine out of the car
Matty
Old Aug 14, 2007 | 06:57 PM
McGoo 69's Avatar
McGoo 69
anyone?
Old Aug 14, 2007 | 08:15 PM
JesseT's Avatar
JesseT
Do you understand the size of the answer needed to fully answer to our question?
Also, "best" and "most efficiant way to do it" don't usually really go together well. If you have something more specific, I'm happy to help.
Old Aug 14, 2007 | 08:40 PM
McGoo 69's Avatar
McGoo 69
im not after anything to complex as its going to be my first major engine mod. Im good with mechanics but ive never turbo'd anything before.
Im not looking for huge BHP i just want to turbo my engine the simplist way to get a idea of things.
Also im not looking for a huge answer just need pointing in the right direction of the best turbo guide, thats if there is a guide about on it
Matty
Old Aug 17, 2007 | 03:42 PM
McGoo 69's Avatar
McGoo 69
has no one got a good guide on how to turbo a zetec then
Old Aug 17, 2007 | 07:34 PM
steve7786's Avatar
steve7786
The last 2 months worth of performance ford magazine has shown how ti build up a zetec turbo engine on a budget.
Old Aug 18, 2007 | 11:33 AM
jawanne's Avatar
jawanne
hi look on the inter net and put in zvh turbo conversion a site is on there and tells you step by step hope that helps////////
Old Aug 21, 2007 | 11:33 AM
Matt_fez's Avatar
Matt_fez
ZT massive! Aight!
check out:
http://www.fiestaturbo.com/articles/zetecturbo/
and
www.zetec-turbo.co.uk
Old Dec 19, 2009 | 06:53 PM
79elton79's Avatar
79elton79
Default car
hi,i have an 18 zetec engine.i would like to make a turbo too.i can do turbo with it or not?what advice can you give me. thanks
Old Dec 19, 2009 | 07:26 PM
jammerrs's Avatar
jammerrs
my simple advice would be...
t3 turbo and exhaust from a ERST
managment and inlet from a FRST
(they will both need modifing to fit)
a decompression plate
ERST intercooler
then the ecu will need to be remapped with bigger injectors
thats all i know for the easy way to get a turbo zetec.
should see 190-200ish
Old Dec 19, 2009 | 07:30 PM
jammerrs's Avatar
jammerrs
just read your spec again...
you seem to have spent good money on the spec you have, so the choice is yours, personally id add cams and a st170 manifold to your spec.
but the final decision is yours
Old Dec 20, 2009 | 03:34 AM
dug112y's Avatar
dug112y
passionford pro
whats your budget? if you dont have the cash handy dont start it as it will turn into a mission.
Old Dec 20, 2009 | 10:17 AM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
this is the spec i would use on a budget,
secondhand 2.0l engine Ł150 (and fook the 1.8 bottom end off )
bebore to 2.1 litres ,honed , drilled and tapped for extra breather ports Ł200/300
rods and pistons Ł1000 (area six motorsport) (these are a must for reliable power)
erst manifold Ł30
all new gaskets Ł100
new oil pump Ł70
new water pump Ł50
focus multilayer headgasket from ford Ł30
your head Ł n/a
standard cams Łn/a
single uprated valve springs (area six motorsport ) (these are amust if you are running over 12psi)
your rs 1800 inlet Łn/a (with idle valve taken off and use of a fiesta turbo throttle body)
fiesta turbo throttle body Ł30
rs 1800 sump Łn/a
drilling and welding for oil returns on your sump front and rear Ł40
t34 turbo Ł850
arp headbolts Ł100
injectors x4 Ł250
cossie air filter Ł100
boost pipes stainless or alloy Ł150
silicon pipes Ł250
bailey breather tank Ł200
fiesta turbo ecu ofab + wiring harness Ł250+
fuel pressure reg Ł100 (weber to permitt use of your fuel rail)
cvh flywheel with holes drilled out to 11mm
all new sensors , water ,air ,cam ,crank etc Ł150
2.5 bar map sensor Ł75
ap racing clutch Ł380 (area six motosport)
and finally a live map Ł250 (ahmed bajoo highly recomended)
all this should see a genuine 300+ bhp at 20 psi
you could then sell the unwanted 2.0 litre head Ł100 and the 1.8 bottom end Ł100 to get some cash back
these are all rough prices and you may be able to find alot of stuff cheaper on ebay , passionford etc
hope this helps
cheers paul
Old Sep 16, 2011 | 06:43 PM
als fiestie's Avatar
als fiestie
Default zetec turbo help ?
hello people was just reading up on the price guide and was wondering which parts i could use off of both engines???
i have a frst with 1.6 cvh turbo engine with t3 turbo,beige injectors,ofab management,stage 2 bajoo chip and 31 actuator. with a full standard mondeo zetec with 2.0 zetec blacktop engine.
wanting to make a zetec turbo for fiestie so was wondering what could i salvage from the cvh?? ie inlet manifold, pumps, ecu etc...
thanks
Old Sep 17, 2011 | 07:59 PM
Maki's Avatar
Maki
exhaust manifold, loom, ecu, maybe turbo, but not much power out of T3 on 2,0.
JoeyBoyden
Jan 4, 2024 02:36 PM
robnock
21
May 13, 2019 05:29 PM
Chopshop85
Aug 17, 2015 06:38 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
