cosworth engine loom relays/sensor
Old Aug 11, 2007 | 06:57 PM
grsford's Avatar
grsford
Default cosworth engine loom relays/sensor
ive nearly finished a cosworth engine management conversion on my rst and i wanted to no what the purple relay/holder was for and if the car would run without it?
also im going to be using a l8 with pf09 tps but i have no idea if the loom has been converted for the pf09 in the past as ive got it now the red wire is on the left had side of the sensor is this correct?
thanks for your help in advance
thanks glenn
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
