cut out
Old Aug 10, 2007 | 08:25 AM
craig todd's Avatar
craig todd
Default cut out
2wd saff
when my car gets warm it cuts out atleast twice, sometimes more, it starts back up straight away, if i'm on the motorway it will die and splutter for a few seconds, then its ok, it will do this a few times then its fine.
anyone got any ideas what this is as its driving me crazy.
cheers craig
Old Aug 11, 2007 | 01:31 PM
craig todd's Avatar
craig todd
anyone please.
just been out, it just cuts out once up to temp, any ideas?
cheers craig
Old Aug 11, 2007 | 01:42 PM
You would do well to ascertain whether it is electricalor fuel in nature.
It is almost defo electrical, I would first when the engine is running do a wiggle test on all the connectors, especially the CPS connector, to see if it can be made to stop, chnces are it is a silly little bad joint break/somewhere.
As it only does it when it's hot this again is looking more likely to be electrical in nature.
Old Aug 11, 2007 | 02:44 PM
craig todd's Avatar
craig todd
thanks tabetha, i will do some checks on the conectors.
cheers craig
Old Aug 11, 2007 | 03:35 PM
It cudnt b phase sensor cud it. I know the insulation on the wires crack n can cause all sorts of faults. The phase sensor is in ur dizzy cap just in case u didnt know where it was.
Old Aug 11, 2007 | 04:24 PM
craig todd's Avatar
craig todd
i'll try that one as well, cheers.
will do the checks at work tonite.
Old Aug 11, 2007 | 06:44 PM
I have known the ignition amps to stop like this when they are hot, due to having no HEAT COMPOUND behind them where they sit on the alloy heatsink.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
cossirob
Sep 16, 2015 07:39 PM
