wont start
Old Aug 8, 2007 | 09:31 AM
cosworth_wannabee's Avatar
cosworth_wannabee
Default wont start
ok, i have put my xr2 engine into my mk4 escort, but i have had to wire up the ignition myself as the previous engine has hcs management.
i had to guess what way round the posetive/negative (from coil) and ground go to the three pins on the ignition module on the dizzy. are there any components in there u can damage if u get the wires the rong way round lol??
as far as i know, ive tried every combination with the 3 pins on the dizzy, and ive changed the coil and the dizzy cap.
should i try changing the whole dizzy assembly with ignition module and find out what way the wires defo go on the module?? (that way ive changed eerything)
am i missing something out though???
can anyone sujjest anything?
Old Aug 8, 2007 | 04:15 PM
messcortmk6's Avatar
messcortmk6
does the engine turn over, awhy dont you check if you actually have a spark by removing the plug and attatching the HT lead, put the end of plug on rocker and turn her over, then you will see if she is sparking which means its a different problem.
Old Aug 8, 2007 | 04:33 PM
cosworth_wannabee
tried all that, the engine spins, but theres no spark, im gna try a different ignition module on top of the dizzy cos if ive wired it up wrong iv probs fried it lol.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
