Group a coil
Old Aug 8, 2007 | 02:37 PM
whittyscossy's Avatar
whittyscossy
Default Group a coil
Hi all i have a grp a coil i want to fit but i dont know what wires go where on the coil from old one?
cheers whitty
Old Aug 8, 2007 | 06:16 PM
Just note which colour wiores are + and - on your old coil as it will be marked.
You now have two options either cut off the terminals/boot connectors, and fitr new spade termianls, or use bullet terminals to fit into the boot terminals and make up a lead with a spade terminal on each end, female to suit the group a coil terminals.
Look CAREFULLY at each set of twin spade termianls on the new coil and you will see the + and - markings in the space between the terminals.
POLARITY is VITAL.
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
IainRS1700T
Sep 25, 2015 06:44 AM
beller
Sep 21, 2015 04:13 AM
