isky valve spring question
Old Jul 28, 2007 | 09:45 AM
killerscum01's Avatar
killerscum01
Default isky valve spring question
Hi all.
in a cosworth engine (4x4) that has montune cams (mt30 exhaust and mtpl9 inlet) and isky valve springs, is it necessary to machine the head for the spring seat and if so by how much?
It is impossible to check the clearance with the cam and tappet installed.
any help greatly apreciated.
Thanks
Old Jul 29, 2007 | 12:04 PM
2001ode's Avatar
2001ode
Default Re: isky valve spring question
Originally Posted by killerscum01
Hi all.
Thanks
Hi,
You can check clearance spring.
If your head is of (complete, with camshaft fitted), install a 1.5 mm jauge between lifter and one inlet cam (in ex), and turn carefully inlet cameshaft with 24 mm. tool. If camshaft "block" , your spring clearance is to short. If camshaft pass, clearance is 1.5 mm. minimum and is OK.
If your head is on, same process, without timing belt, and with all pistons on middle of stroke.
Claude.
Old Jul 30, 2007 | 07:20 PM
killerscum01
Thank you very much for the advice.
So to clarify: you put a 1.5mm feeler guage between the cam and tappet and turn over, and if it clears its fine.
Cheers: Bart
Topjoe9
Sep 12, 2015 09:50 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
cossirob
Sep 3, 2015 09:17 PM
