Brake upgrade help
Old Jul 27, 2007 | 10:15 PM
djsri's Avatar
djsri
Default Brake upgrade help
Hi all
I've just done Hi-Spec 4 pot cailpers 310mm upfront and cosworth rear disc conversion (not vented) running through wilwood bias valve. Master cylinder and servo from escort rs turbo but seem to be having problems with brake travel. Cant get pressure on the brake peddle until i pump up and down few times then leave couple of seconds then travel almost to the floor again. Have bled system god knows how many times but still no joy so now i'm thinking the mast cylinder is not up to the job? Anyone know what master cylinder i could use on a mk4 escort van?
cheers
pete
Old Jul 28, 2007 | 12:01 AM
jon@work's Avatar
jon@work
the cossie rear disc conversion is your problem - I'll bet the rear caliper bleed nipples aren't the highest point, so trapping air when you bleed them
undo the caliper mounting bolts and rotate the caliper around slightly so that the bleed nipple is at its highest and bleed the brakes again
Old Jul 28, 2007 | 12:45 AM
djsri's Avatar
djsri
I've got the rear setup like this, you still think this could be the problem and not the master cylinder man enough?
Old Jul 30, 2007 | 08:13 AM
djsri's Avatar
djsri
Anyone else think it could be the master cylinder b4 i go and buy something else?
Old Jul 30, 2007 | 01:26 PM
jon@work's Avatar
jon@work
just unbolt the rear calipers and bleed as per above
Old Jul 30, 2007 | 01:52 PM
djsri's Avatar
djsri
ok m8 will do
You think it could still be air as i've had bleed system on at 20psi pushing it through?
Old Jul 30, 2007 | 03:41 PM
jon@work's Avatar
jon@work
yes - the air will collect above the bleed nipple whatever the pressure
Old Jul 30, 2007 | 10:42 PM
djsri's Avatar
djsri
jon@work
You the man!!!!
done what you said, worked a treat well happy m8 thanks very much saved me loads of money and can now sleep...
cheers
pete
Old Jul 30, 2007 | 11:59 PM
jon@work's Avatar
jon@work
happy to help
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
