saph misifre
Old Jul 20, 2007 | 12:00 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default saph misifre
what would cause a 2wd saph to misfire when hot, only does it on full boost
is this something to do with the water temp sensor or am i wrong?
Old Jul 20, 2007 | 01:15 PM
Staffi's Avatar
Staffi
I'd like to know this aswell Dan, mines developed one latley
Mind you mines off to Karl to be setup soon, the cold start is shite on mine aswell..
Old Jul 20, 2007 | 01:57 PM
stage 3 muppet's Avatar
stage 3 muppet
try the phase sensor and also crank pulley sensor usually wires corrode and go brittle
Old Jul 20, 2007 | 01:58 PM
stage 3 muppet
also forgot to say check the plug gapping
Old Jul 20, 2007 | 02:19 PM
Std fit coils are crap at the best of times, so get a group a, the difference is enormous.
As said the phase sensor wiring goes brittle and flakes away, later ones with 1 red 1 blue wire much better as got decent insulation.
Nothing to do with CTS.
Could be leads also, Magnecor are very good on these.
Old Jul 20, 2007 | 03:05 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers guys
Old Jul 21, 2007 | 09:05 PM
costina's Avatar
costina
Live long and prosper!!
Plugs breaking down when hot or ign amp
What spec Dan????
Paul
Old Aug 9, 2007 | 07:47 PM
JanDK's Avatar
JanDK
ignition amp???? Everybody I ask for advise or just talks to says ign.amps DONT fail sometimes.. they break down completly if they do.
Or can you make me a little more clever on this subject ??
Old Aug 10, 2007 | 06:03 AM
Any electronic component is capable of being dodgy just at times, eg if it has a dry joint, that will do it.
Any boost induced misfire is very likely to be lack of sparks due to bad coil as this is the hardest time to generate spark due to the cylinder pressure, the higher it is the harder it is to spark for the plug the more voltage it needs.
Old Aug 10, 2007 | 06:25 AM
JanDK's Avatar
JanDK
Thanks... I dont want to hijack this thread.
But mine does missfire with the gear in neutral and accelerating withOUT boost and ofcause with boost. same revs ! EVERTHING is new and adjusted.. besides the ign amp.. thats why I find it interesting. And I have had exactly that thought about the ign amp cause of my experience from work.
Old Aug 10, 2007 | 12:26 PM
costina's Avatar
costina
Jan< check u have correct voltage at the ignition amp and coil,may just be a wiring fault as these looms are getting old now
Could be something as simple as the amp getting hot and not disipating the heat well??? Has it ever been removed off the alloy heat sink????
If so theres prob no conductive paste on it???
Just a thought
Paul
Old Aug 10, 2007 | 05:48 PM
Cossy Mike's Avatar
Cossy Mike
Same problem with mine, I replaced the Spark Plugs,Distributor Cap, rotor arm, HT lead and the coil.
It turned out to be the coil, I bought a Group A coil from Motorsport Developements, best £40 I have spent. Enormous difference, only wish I had done it sooner.
Hope this helps.
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
landaqmabba
Sep 15, 2015 07:16 PM
