testing a rev counter ?
Old Jul 16, 2007 | 03:36 PM
Windle's Avatar
Windle
Default testing a rev counter ?
mines decided to give in
its EFI engine with EFi clocks so usually reads ok, but recentely its doing nothing
can i test them to see if they are dead or its the wirring ?
Old Jul 31, 2007 | 10:23 AM
Windle's Avatar
Windle
up as they are still dead
can i test a pin on the ECU with a volt meter or anything and then trace it back to see if its wirring or clocks at fault ?
Old Jul 31, 2007 | 01:52 PM
messcortmk6's Avatar
messcortmk6
not too sure matey but why not get some more clocks and see if they work??
might be the clock itself.
if nothing works i reccomend a hammer!
Old Jul 31, 2007 | 02:03 PM
Windle's Avatar
Windle
the EFI clocks are quite hard to come by and as a result seam to be dear. So need to make sure first!
Old Jul 31, 2007 | 02:41 PM
messcortmk6
yeah is suppose. mabye you could just clean then fiddle the connectors. might help.
Old Jul 31, 2007 | 03:03 PM
Windle's Avatar
Windle
have had clocks out and all connections look fine at the clock end
Old Jul 31, 2007 | 10:53 PM
SafeChav's Avatar
SafeChav
Either use a scope on the rev counter signal wire.
Or rapidly switch the feed wire to earth and see if the rev counter moves.
Old Jul 31, 2007 | 11:19 PM
Windle's Avatar
Windle
i'm sorry a what
i have tried messing giving earth and the counter seamed to move a little, but didn;t move much past zero, was expecting to get it right round with full earth or something
Old Aug 1, 2007 | 10:06 AM
SafeChav's Avatar
SafeChav
Well no you wont because its pulsed and youj'll never be able to do it at that kind of speed.
Look on the inner wing by EDIS, theres some green wires and you'll see a little black thingy plugged in, bet you thats knackered
Old Aug 1, 2007 | 03:48 PM
Windle's Avatar
Windle
there is in deed a little random plug on its own
test it? or can you get rid of it infact wtf is it lol ?
Old Aug 1, 2007 | 11:24 PM
SafeChav's Avatar
SafeChav
What sort of plug is it? What loom does the car have?
Old Aug 2, 2007 | 10:19 AM
Windle's Avatar
Windle
looks like a standard 2 pin one the same as an injector one?
the loom is a fiesta turbo engine loom
Old Aug 2, 2007 | 11:59 AM
SafeChav's Avatar
SafeChav
Has it got 2 green wires on it yea?
Old Aug 2, 2007 | 01:58 PM
Windle's Avatar
Windle
not at the car at the min but does ring a bell yes, will have a check later
Old Aug 2, 2007 | 06:18 PM
Windle's Avatar
Windle
pretty sure thats the problem well done again
moved tape back and one of the wires has totally frayed away could do with checking the rest of this loom me thinks
i have no head on yet so sadley cant test the counter just yet lol
Old Aug 3, 2007 | 01:01 AM
SafeChav's Avatar
SafeChav
Oh so you've got the condensor that plugs into that plug then?
Old Aug 4, 2007 | 01:04 PM
Windle's Avatar
Windle
its just a little box screwed to my inner wing is that a condensor ?what does it do, if i recall i did need it on and earther for it to work properly
Old Aug 6, 2007 | 09:04 PM
SafeChav's Avatar
SafeChav
bridge the plug with a piece of wire and you'll probably find it works!
Best to have one really! Can get you a second hand one if need be.
Old Aug 7, 2007 | 08:51 PM
Windle's Avatar
Windle
will try and repair the thing first, makes sence as it became tempremental and then just died so could be just the thing
Old Aug 9, 2007 | 07:17 PM
Windle's Avatar
Windle
deffo was that, fired car up tonight and rev counter working fine
TPM961
Jan 15, 2018 10:50 AM
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
hopper350
Sep 4, 2015 12:53 AM
