engine builders help required
Old Jul 10, 2007 | 07:25 PM
juffer's Avatar
juffer
Default engine builders help required
I had bettom end knocking so i removed the crank and sure enough the bearings and crank no good. I had the crank reground and they said at the engerneers it is a 1.8 cvh crank,They supplied the bearings to fit my crank but don't fit the rods. Thats where the problems started. I can't get bearings to fit my crank and rods.
I believe to have a 1.9 bored out 1.6 cvh rst block
1.8 cvh crank
mahle pistons
I cant identify the rods with a name such as ford ect.The rods have studs fixed in with a nut that holds the cap on not like standard with a bolt. They are covered in numbers but some are ground out. They are:
22269z2jgsbmlp (on one side)
88218122 w2168???????? (ground out on other side)
The pisons also have these numbers on them if this helps: r101 b2/61
I need to identify these as i cant get parts. Any help would be great as i have a potental scrap engine. any engine buildes on here got any ideas.
_________________
Old Jul 10, 2007 | 11:19 PM
SafeChav's Avatar
SafeChav
Pictures would probably be useful
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
borboyous
Aug 22, 2015 11:17 AM
mrice0107
Aug 21, 2015 07:55 PM
yawiejon
15
Aug 9, 2015 06:36 PM
