XR2I Turbo
Old Jul 8, 2007 | 04:42 PM
taz8520's Avatar
taz8520
Default XR2I Turbo
Hi have XR2I and one of my machanic mates has a turbo he was gonna fit on his escort but was thinking of buyin off him, comes with turbo (not sure wot make model ) ecu, samco hoses, intercooler and manifold, but bit unsure what else i will need, he said about a conversion plate to fit between the exhaust manifold and engine and some oil feed pipes, anyone help ???
Old Jul 8, 2007 | 07:44 PM
SafeChav's Avatar
SafeChav
Conversion plate?
You need to find out what turbo it is........but a ERST manifold is the easy option for fitting
Old Jul 8, 2007 | 11:46 PM
taz8520's Avatar
taz8520
Yea will find out 2moz, so it would work with a low ish boost turbo?? and where would i get that manifold, none on ebay or anywhere
Old Jul 9, 2007 | 09:55 PM
SafeChav's Avatar
SafeChav
It would but as you say it HAS to be low boost, and you will need some way of getting sufficient fuelling on boost otherwise you'll just melt down
Old Jul 9, 2007 | 10:26 PM
jayjay's Avatar
jayjay
iv got one mate wher do you live
Old Jul 10, 2007 | 10:59 PM
taz8520's Avatar
taz8520
My mate said he not sure what model but its a garret turbo and it runs at low boost , might aswell give it a shot for the sake of £50 but still unsure what extra i need, how will i connect to oil feeds so my engine???
Old Jul 10, 2007 | 11:15 PM
SafeChav's Avatar
SafeChav
Garret make loads of turbos though
Oil feed is easy enough, a T piece adaptor and a feed hose.
Old Jul 10, 2007 | 11:20 PM
taz8520's Avatar
taz8520
Oh lol, i don't know anyting really about turbos, so a T piece adaptor on the inlet and outlet of the turbo oil feeds??? and what about the big air intake bit that goes to the injectors mine curves to left to air box but RST's i seen bend to right so would i need a new one?
Old Jul 10, 2007 | 11:33 PM
SafeChav's Avatar
SafeChav
No you need a T piece where the oil pressure switch bolts into the block.
Yes you will need a different charge carrier
Old Jul 10, 2007 | 11:53 PM
taz8520's Avatar
taz8520
Cool cheers think im getting there now, i would need a air cone aswel ??
Old Jul 11, 2007 | 06:48 PM
george escort's Avatar
george escort
well i turbod my 1.4 befor i put a zvh in and did nothing to the engine at all just bolted the erst turbo on run oil feed from oil pressure swich welded return in sump conected all up and ran 7 psi boose with blue frst injectors and more fuel pressure with an fse valve befor i took it out i ran 15 psi and full fuel pressure to try and kill it for 500 miles and diddent die when i striped it there was no dammage to pistons at all and still ran sweet aswell befor i took it out i would say you mite need bigger injectors aswell as an fse valve but i would only run 7 psi max if you want it to last on standard compression.
Old Jul 12, 2007 | 11:19 AM
SafeChav's Avatar
SafeChav
Lucky
VERY lucky
Old Jul 12, 2007 | 10:47 PM
taz8520's Avatar
taz8520
My mate said about 2 head gaskets aswell ??
Old Jul 13, 2007 | 12:49 PM
SafeChav's Avatar
SafeChav
your mate sounds like a bit of a cunt
Old Jul 13, 2007 | 02:39 PM
taz8520's Avatar
taz8520
Yes he is
Old Jul 13, 2007 | 02:41 PM
SafeChav's Avatar
SafeChav
Old Jul 13, 2007 | 06:00 PM
taz8520's Avatar
taz8520
So i need. a RST exhaust mainfold, a t-bar near the oil pressure switch to get oil in turbo and a exit on the slump??? anything else??
Old Jul 18, 2007 | 10:48 PM
taz8520's Avatar
taz8520
I got the hoses, intercooler and ECU at the moment, i plugged the ECU in earlier and it only made the engine tick over, wouldn't start does it need the turbo fitted 1st or is the ECU gone???
Old Jul 18, 2007 | 10:51 PM
SafeChav's Avatar
SafeChav
it ticked over but wouldnt start?
Old Jul 19, 2007 | 06:52 AM
taz8520's Avatar
taz8520
soz not ticked over mean it cranks over but won't start
Old Jul 19, 2007 | 10:23 AM
SafeChav's Avatar
SafeChav
Hard to say just from that info mate
Old Jul 21, 2007 | 09:10 PM
taz8520's Avatar
taz8520
The RST ecu won't work with out the Turbo will it??
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
