Cosworth boost help
Old Jun 24, 2007 | 10:24 PM
CosieAL's Avatar
CosieAL
Default Cosworth boost help
Hi
i have a 1988 saph cosworth running greens, 3 bar MAP sensor -31 Actuator,RS500 Intercooler, On standard ECU
The car is running 10psi what can i turn the boost to without causing damage?
Old Jun 25, 2007 | 12:03 AM
jon@work's Avatar
jon@work
Default Re: Cosworth boost help
Originally Posted by CosieAL
standard ECU
doubt it
Old Jun 25, 2007 | 12:18 AM
CosieAL's Avatar
CosieAL
its been put back to standard chip
So your input was a waste of time as you dont even know my car
Old Jun 25, 2007 | 07:50 AM
It is NOT going to work correctly with the combo of parts(std chip).
I would NOT turn the boost up but be thankfull it has not done some damage yet, why would you want this to run correctly ?
The ONLY way this will run correct AFR is to have the chip changed or overwritten or change to the INJECTORS and MAP sesnsor that the(std) chip has been CALIBRATED FOR.
The point that jon@work was trying to mkae is it is suicidle to try to run this combo with std chip, he as I found it hard to beleive anyone would, or even expect it to work.
The "MIX" of parts must be right ie chip(settings) goes with certain injectors, map etc, you can't do pick + mix like in woolworths!!
You can of course have your chip rewritten on the oe chip with these bits, but would not advise changing the boost at all, just drive gently until it has been fixed, but it is your car, so turn away(boost) if so desired it can only go bang, and surely not worth it.
Old Jun 25, 2007 | 10:07 AM
foreigneRS's Avatar
foreigneRS
Testing the future
his input was perfectly valid and it seems that you don't know your arse from elbow
if you did, you would not be driving it like that
Old Jun 25, 2007 | 01:56 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Hi
The standard chip will be assuming you're on yellow/standard injectors, which don't flow the same amount of fuel as your greens. This will completely upset the AFR. And we all know what that can mean...
The absolute least that needs to changed is the chip - a stage 3 or 2 one that will put the right amount of fuel (relative to stage 1 or standard!) into the cylinders. Or if you're taking it back to standard, swap the injectors for yellows and put a 2 bar MAP sensor on it.
In addition, the standard chip will cut the boost at 10psi because it's not capable of running higher. You can try and wind the actuator on as much as you want, but the ECU will have the amal valve wide open in the direction of the airbox.
Old Jun 25, 2007 | 03:06 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you've missed the biggest part of the problem, which is not the injectors. it's the MAP sensor
the injectors will give more fuel, which is not ideal but is less dangerous to short term engine health than less fuel
but the MAP sensor will completely screw up the fuelling on boost, which is much worse. the ecu will be seeing your 10 psi boost as much less
Old Jun 25, 2007 | 03:09 PM
CosieAL's Avatar
CosieAL
Thanks for the help
Im just going off what i was told by the prev owner
Im not driving the car untill i get a stage3 chip and get it setup correct
Old Jun 25, 2007 | 03:19 PM
Stu @ M Developments's Avatar
PassionFords Creator
She still runs ok?
Lucky man....
Old Jun 25, 2007 | 09:08 PM
BigErn's Avatar
BigErn
How do Al matey, welcome to PF.
Im taking it this is Dans old car (DANNY-B)?
It was running Stage 3 before Dan got it, it also melted before he got it and it got a full rebuild. It was built with greens and 3 bar MAP sensor and put back on standard chip while getting run in I believe. However I think the lad who got it before Dan did not get the chip when he got the car so he just ran it as is for a few months, as did Dan, both of which had no problems at all engine wise. Id still be getting a chip and set up to suit. Its probably safer engine wise and much more fun that way.
Old Jun 25, 2007 | 10:07 PM
CosieAL's Avatar
CosieAL
Alright Ern
Yeah mate thats the very car iv just got hold of a Stage3 chip + ECU Any ideas where to go to get it setup right ?
Any help apreciated mate
BTW is that Harry Tyler in your avi?
Old Jun 26, 2007 | 07:45 AM
foreigneRS's Avatar
foreigneRS
Testing the future
looks like les dawson to me
there's not much to set up when you install a new chip. you need to get the fuel pressure checked, and the chip should come with instructions on how to set the CO pot if you bought a proper one from a reputable supplier. if you didn't, then you're probably not much further forward than using a std chip
Old Jun 26, 2007 | 08:23 PM
BigErn's Avatar
BigErn
foreigneRS it is Les Dawson. The man was a legend.
AL mate fit the chip and it should be ready to run. It is L6 ECU and chip you bought yeah? Take it to Stu or Carwise for a proper set up mate. If you doing it yourself tho then you could ask V-Sport in Boldon to do it. Fuel pressure should be set at 3bar, boost at 23psi and they will check the fuelling and boost all the way through the revs to make sure its not running lean at any point. Not sure how they are at tuning/setting up Cossies but they come in handy for using the rollers after modding to check gains/faults etc.
Old Jun 26, 2007 | 09:14 PM
CosieAL's Avatar
CosieAL
Yeah mate Stage3 L6 chip
Would you be able to check my fuel preasure for abit beer money?
Then ill book it into V-sport
Old Jun 28, 2007 | 06:54 PM
BigErn's Avatar
BigErn
I got no way of checking fuel pressure mate or I would have. Sorry.
Id get it on the rollers asap to see if they pick up on any issues.
blackbeautyzetec
Aug 29, 2015 02:11 PM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
Escortdriver1
Jul 31, 2015 02:36 PM
