not very tech but still need help??
Old Jan 13, 2004 | 03:01 PM
Default not very tech but still need help??
cabriolet is suffering really badly from condenstation in the boot , so bad in fact its soking my carpet !! n e ideas ??
Old Jan 13, 2004 | 03:13 PM
Toe Knee's Avatar
Toe Knee
Is the rubber boot seal perished anywhere?!
Old Jan 13, 2004 | 03:54 PM
kjc300's Avatar
kjc300
probably a leak, thats causing the soaking, thats causing the condensation!!!
Old Jan 13, 2004 | 04:29 PM
Stu @ M Developments's Avatar
PassionFords Creator
Rear light seals is common.
Old Jan 14, 2004 | 12:29 PM
........Or maybe you have what FORD really stands for.......Floods On Rainy Days
Old Jan 14, 2004 | 01:04 PM
davie0146's Avatar
davie0146
rear light cluster are a pain in the erse.
i used a tube of silicone on mine and it worked perfectly. i also use some silica beads to absorb the moisture.
Old Jan 15, 2004 | 02:49 PM
had same prob in my s2 was leak around rear lights check all terminals for corrosion as it causes your lights to do all sorts of weird things when you brake etc
Old Jan 16, 2004 | 10:06 AM
lights working fine but i recon ur right the problem lays there , one of em tends to fill with water
so u saying silicon sealant would work?
Old Jan 16, 2004 | 11:50 AM
Had a similar problem with my Sapph, get some sealant from halfords. Best get automotive grade stuff as it withstands oil, grease, fuel, higher temperatures, etc... than your average bathroom silicone. Also it comes in black which is handy.
Old Jan 17, 2004 | 04:19 PM
I had the same problem with my cabby, it turned out my arieal was letting it in, so its worth looking at that, (i ended up replacing it all toghter)
Old Jan 18, 2004 | 01:43 PM
thanks will take a look at that 2
Old Jan 23, 2004 | 02:14 PM
EXACTLY WHAT I HAD ON MINE, JUST GET THE SEALER OUT, USE ALL WEATHER SILICON, AND GO ALL AROUND THE TOP OF THE LIGHTS.
JOB DONE
Old Jan 25, 2004 | 09:18 PM
st3v3's Avatar
st3v3
take the back lights out replace with new gaskits and a very little smear of gaskit sealant will do you a good un,i had this on my s2,took me ages to find it as well
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
