ecoz strange engine problem
Old Jan 11, 2004 | 10:58 PM
velocity's Avatar
velocity
Default ecoz strange engine problem
a mate got a new turbo fitted reciently and i was there when it was being fitted it was done right.heres the problem.when we left the garage for a blast the engine developed a miss or what appeares to be a rev limit at 4000 rpm reguardles of boost setting (16 psi to 20psi) it will even do it with the car stopped and you bring the revs up to 4000 approx.the she limits sounds like bep bep bep bep.........
if you push flat out it still wont go above this rpm even when stopped.
and its not happening all the time but it appears to be getting worse
we have changed, dizzy,crank sensor,map sensor (3 bar),plugs,leads,coil,
but its not making sence as it drove in perfect.its like hitting the sound barrier at 4000 rpm but from idle up to it and beyond it all is ok.i know the obvious thing to suspect is the turbo but it happens also when unloaded and only at one rev setting. i need the guru.s on this one
Old Jan 11, 2004 | 11:02 PM
kjc300's Avatar
kjc300
Check all your sensors are plugged in - mine went like that when i forgot to plug the coolant temp sensor back in after I changed a blown coolant hose!!!!!
Old Jan 11, 2004 | 11:12 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its in limp home mode. Total sensor failure mate.
Old Jan 11, 2004 | 11:18 PM
velocity's Avatar
velocity
cheers lads any idea which one as there is a secs monitor hooked into the ecu and all the readings are normal for map,temp,tps,coolant,voltage.rpm.
Old Jan 11, 2004 | 11:50 PM
Ahh, just read it properly!!
A turbo was fitted eh?
Plug the lambda sensor back in
Old Jan 11, 2004 | 11:51 PM
velocity,
Why didnt you take it back mate?
Old Jan 12, 2004 | 12:00 AM
velocity's Avatar
velocity
well the man was scratching his head aswell ,i,m almost sure the lambda is back in,i didnt think the p8 was that sensitive if the lambda was nuked or missing.i melted the wires on my 4x4 saph lambda sensor and had to disconnect it and it never did that although i know its an L8
thanks for your help
Old Jan 12, 2004 | 09:19 AM
P8 will introduce a safety 4K limiter upon ANY sensor failure mate.
Old Jan 12, 2004 | 03:56 PM
velocity's Avatar
velocity
thats the kind of info that is worth its weight in gold .thank god for passion ford and all who post in her
Old Jan 12, 2004 | 04:04 PM
Let us know if you fix her, so anyone in future can refer to it.
Old Jan 12, 2004 | 06:02 PM
velocity's Avatar
velocity
will do.looks like a few nights with the meter and the probe.
Old Jan 19, 2004 | 11:31 PM
velocity's Avatar
velocity
problem sorted turned out to be a nuked lambda sensor
cheers stu
Old Jan 19, 2004 | 11:32 PM
richm's Avatar
richm
Stu
Old Jan 23, 2004 | 11:37 PM
Glad its sorted mate
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
41
Aug 21, 2015 06:47 AM
tankybaby66
Aug 9, 2015 07:13 AM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
muz
Aug 1, 2015 06:48 AM
