what smoke is this helpppppppppppppppppp
Old Sep 16, 2004 | 10:11 PM
abdr500's Avatar
abdr500
Default what smoke is this helpppppppppppppppppp
hi i have a 2.0 turbo i start it and it smokes and then when its warmed up it stops smokeing and on idel thers no smoke but when you rev it you get a cloud of smoke and then it idels with no smoke if you keep the revs up then it will smoke all the time let it idel agfine and smokes gone what is it helpppppppppppppppp
Old Sep 16, 2004 | 10:21 PM
EvilFranky's Avatar
EvilFranky
What colour is it for a start mate?
Old Sep 16, 2004 | 10:36 PM
abdr500's Avatar
abdr500
its blue
Old Sep 16, 2004 | 10:41 PM
EvilFranky's Avatar
EvilFranky
Defo oil then!
Valve stem seals at a guess?
Old Sep 16, 2004 | 11:31 PM
abdr500's Avatar
abdr500
it wount smoke on idel but it smokes when you rev it so can that still be stem seals or is it rings
Old Sep 17, 2004 | 04:34 PM
Rocco's Avatar
Rocco
do you still get the smoke when the turbo cust in? i would say rings,
but DO a comp test 1st, have you just serviced the car??
stem seals would just smoke at idle
Old Sep 17, 2004 | 06:58 PM
abdr500's Avatar
abdr500
yea its when the turbo cuts in if you rev it on the spot it smokes and from the breather pipe the a bit of smoke to i think its rings what do you think
Old Sep 17, 2004 | 08:05 PM
Rocco's Avatar
Rocco
from wot you say i would go with piston rings & if the breather is spitting out shit too but do a comp test as i said they are only £15 from halford & will not take you long & may track it down to the offending cylinder
Old Sep 17, 2004 | 08:30 PM
b13nde's Avatar
b13nde
i would say turbo seals are on way out and its driping in to exhaust side just check turbo free play if it aint running bad i woundnt rings or it would have picked up by now and put the piston oil the oil filter
Old Sep 17, 2004 | 09:21 PM
abdr500's Avatar
abdr500
comprsion is ok and any way it wouldnt show on the test as it will not show if th oil ring ia fucked only if comprision is down i hear what your saying but comprsion can still be good even if the oil ring is fucked ..ohh and if you lift the dip stick up it spits out oil and if you rev it with out the dip stick you can end up coverd in oil please ho many people say ring s i do and how many say turbo i will carry out work acorrdingly to the amount of people that say turbo or ring so come on people give your vote
Old Sep 18, 2004 | 10:22 AM
b13nde's Avatar
b13nde
well if you had said about the dip stick then it gives the game away really
Old Sep 18, 2004 | 12:48 PM
abdr500's Avatar
abdr500
so r you confirming thats it is the ring if so i will start striping it doun thanks for your helpppppppp
Old Sep 22, 2004 | 07:43 PM
b13nde's Avatar
b13nde
yes rings
Old Sep 22, 2004 | 08:43 PM
abdr500's Avatar
abdr500
after when you let the car run for about 10 min it stops smoking and when you rev it to about 7 k it smokes a bit out the back but it does get better once left runnig could that still be rings
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
A.t.p
Sep 29, 2015 05:04 PM
Brickhouse
Sep 21, 2015 04:31 PM
