Escort GTI - Engine people needed!!!
Old Sep 22, 2004 | 07:02 PM
dvid's Avatar
dvid
Default Escort GTI - Engine people needed!!!
Hi, hopefully someone can help me out with this one!
My GTI keeps getting the stutters! when driving along i randomly get this ticking noise, then the car starts jerking around and then can cut out on its own, or will cut out when i put clutch in... Normally if i keep my foot to the floor it goes away.....
As amusing as my cars attempt at a Paula Radcliffe impression is, it would be much appreciated if i could get all the way home!
Today my mechanic bloke changed the fuel pressure regulator from a bodged job to a new one, and took off the pipercross induction kit (they are shite!) and put the standard airbox back on with K&N panel..
Any clues at to what this could be would be great!
Old Sep 22, 2004 | 07:16 PM
b13nde's Avatar
b13nde
from this end sounds like it you be a lifter i know the zetec engines suffer with lifter probs one reason is the engine oil is the wrong grade or is over used when did you last change it and what did you put in it
Old Sep 22, 2004 | 07:27 PM
dvid's Avatar
dvid
lol had the car about 3 months done around 3K miles havent changed it, but levels are ok? this problem hasnt been there since i bought it, only for the last month, was cos someone fitted an FSE valve to it, AA fiddled with it and sorted that out and it was fine 4 a while, then it came back
Old Sep 22, 2004 | 07:32 PM
b13nde's Avatar
b13nde
im with oil fse wouldnt give a noise it would just die like you run out of petrol if it was to low and if it was to much you would get black smoke every where and a blown engine
Old Sep 22, 2004 | 07:35 PM
dvid's Avatar
dvid
who knows whats up with the feckin thing, ripped out my FSE valve now theres a standard regulator on there, but same problem! no smoke no nothing, just ticking, then it stutturs and if you stop with clutch in it will cut out, if you keep driving with foot down it sorts itself out and goes away for a bit....
Old Sep 22, 2004 | 07:39 PM
b13nde's Avatar
b13nde
just check theres no water in the head round the h.t leads
Old Sep 22, 2004 | 07:40 PM
dvid's Avatar
dvid
lol nope cos I also had my custom rocker cover fitted today with new gasket so nothing there either!! wierd huh?
Old Sep 22, 2004 | 07:42 PM
b13nde's Avatar
b13nde
check and maybe change the oil to fords spec
dvid's Avatar
dvid
ok thanksmate, i won tbother you any more!!
Old Sep 22, 2004 | 07:46 PM
b13nde's Avatar
b13nde
thats ok this iswhy we are here hope this keeps it 99.9 percent sure
Old Sep 22, 2004 | 08:20 PM
Lee @ Fusion's Avatar
Lee @ Fusion
Mine did this , was the fooooooookin HT leads , arcing out and were generally fooked .
Got a set from a motor factor and all was well again .
Old Sep 22, 2004 | 09:07 PM
dvid's Avatar
dvid
Thanks for all your help guys! maybe thats a good route to take.... HT LEads and plugs it is!
JoeyBoyden
Jan 4, 2024 02:36 PM
col93saphcos
Aug 7, 2015 03:21 PM
Old ford
Jul 31, 2015 06:50 AM
