zetec timing! help plz
Old Mar 21, 2007 | 07:46 PM
p-38-king's Avatar
p-38-king
Default zetec timing! help plz
hi all i got a 1.8 zetec mondeo on a v reg the and the cam belt snapped we checkied it over and the pistons are fine but the valves in piston 1 are bent so i guess it needs a new head, its a mondeo on a v wich is a 99 so i would like to know would a zetec 1.8 escort or any other 1.8 zetec head fit ? the one in my mondeo is a black top zetec any help please would be great
if ya can help pm me or sumat i am bit stuck
Old Mar 22, 2007 | 07:23 AM
Just needs a new valve, easy job cheaper than a new head as well, just get new valve and lap it in.
01603 866999 is the number for MONDEOPART/focus part as well, very good chaps to help you.
Old Mar 22, 2007 | 08:28 AM
Maki's Avatar
Maki
I double that
Old Mar 22, 2007 | 03:43 PM
p-38-king's Avatar
p-38-king
so new valves be cheaper??
and also what about the valve guids wud they be ok? when i took the head off the inlet and exhaust valves was jammed open so i guess there well bent lol
Old Mar 22, 2007 | 07:07 PM
p-38-king's Avatar
p-38-king
also the bottom pully hasnt got a timing notch on it , it says it has a timing tool wich locks the bottom pully at tdc , well i got the timing pin that you need to lock the bottom pully but there is no hole in the pully or block to put it in ??? any one got any ideas ??
Old Mar 22, 2007 | 07:58 PM
There is a hole in front side of block, behind a 10mm bolt near the bottom, undo this and GENTLY TURN the crank until it contacts the pin on the cranks web inside engine.
You approximate TDC with wheel then turn back say 1/8 turn counter clockwise then install pin then bring onto contact by turning clockwise, you will feel it when it goes not more..
Old Mar 22, 2007 | 08:33 PM
jcrsturbo's Avatar
jcrsturbo
yeh iv just rebuilt a ztech and it not a locking pin, the crank just stops up against it like tabetha sead. and with the cams u need somthing long n thin to go across the slots on the back of the cams. i used a long screw driver.
Old Mar 22, 2007 | 08:39 PM
p-38-king's Avatar
p-38-king
ah i got the locking tool for the cams just got to work out how to put the cams to lock them in place so i can time it once the engine is locked at tdc ..
Old Mar 22, 2007 | 08:43 PM
jcrsturbo's Avatar
jcrsturbo
yeh the slots are off-set so you want the slots to b at the top to fit the tool
Old Mar 22, 2007 | 08:46 PM
p-38-king's Avatar
p-38-king
is there only one way they can go??
Old Mar 22, 2007 | 08:50 PM
jcrsturbo's Avatar
jcrsturbo
yep
Old Mar 22, 2007 | 08:53 PM
p-38-king's Avatar
p-38-king
thanks matey so once i got my crank at tdc ... and the cams locked i can put the timing belt on and it all back together and it willbe ok?
Old Mar 22, 2007 | 09:18 PM
jcrsturbo's Avatar
jcrsturbo
not quite so simple. i take it uv taken the cam pullys off, b4 u put the belt on u gotta do one up, put the belt on, pull the belt tight across the 2 pullys then do the other one up. n make sure you use thread-lock, u dont want em comin undone. but if u aint taken em off then ye should b ok
Old Mar 22, 2007 | 09:20 PM
p-38-king's Avatar
p-38-king
nah the cam pullies are still on the end of the cams so it shud be ok ?
Old Mar 22, 2007 | 09:24 PM
p-38-king's Avatar
p-38-king
oh and on the 1.8 zetec e engine there is a tensioner pully on the bottom near the bottom crank behind the black platic cover it seems my engine hasnt got one which cud of made the belt strip the teeth of it i think ..any clues?? its a 1999 zetec e the manual says its got a tensioner at the bottom neat the crank but when i took the black plastic bit behind the bottom pully of to get the belt out it seem the tensioner isnt there lol any ideas??
Old Mar 22, 2007 | 09:27 PM
jcrsturbo's Avatar
jcrsturbo
yeh. just gotta tension it up. if uv bort a cam belt kit then that shud b easy 2 just gotta bolt it on then pull the pin out once the belts on. put some marks on the cam pullys and bottom pully with some tipex or somthin then turn the engine over by hand n make sur they all line back up again
Old Mar 22, 2007 | 09:37 PM
p-38-king's Avatar
p-38-king
ah ok matey yes just bit strange that the book says the bottom crank where the belt goes round has a tensioner near it but it seems on mine it isnt there lol
Old Mar 22, 2007 | 09:43 PM
jcrsturbo's Avatar
jcrsturbo
the tensioners about half way up on the left if ur facing it
Old Mar 22, 2007 | 09:50 PM
p-38-king's Avatar
p-38-king
no tensioner as you look at the bottom of the engine behind the black plastic cover onthe right side right near the bottom
Old Mar 22, 2007 | 09:59 PM
p-38-king's Avatar
p-38-king
that tensioner there seems to be missing lol and that must be why the belt stripped its teeth
jcrsturbo's Avatar
jcrsturbo
oh rite ok, must b a diffren moddle. but as long as all the locking tools r in should b ok.
Old Mar 22, 2007 | 10:01 PM
jcrsturbo's Avatar
jcrsturbo
not the rite diagram then, tensioner shud b the top left 1
Old Mar 22, 2007 | 10:04 PM
p-38-king's Avatar
p-38-king
no the tensioner is top left but that roller i arrowed isnt there on my engine and it says it shud be lol strange
Old Mar 22, 2007 | 10:15 PM
jcrsturbo's Avatar
jcrsturbo
well that wernt on the engine i did ither. it only looks like a guide pully
Old Mar 22, 2007 | 10:18 PM
p-38-king's Avatar
p-38-king
was it same as mine
Old Mar 22, 2007 | 10:19 PM
p-38-king's Avatar
p-38-king
is it same as yours ??
Old Mar 22, 2007 | 10:26 PM
jcrsturbo's Avatar
jcrsturbo
the pic aint the same as the 1 i did no
Old Mar 22, 2007 | 10:27 PM
p-38-king's Avatar
p-38-king
was it same engine ??
Old Mar 24, 2007 | 02:20 PM
jcrsturbo's Avatar
jcrsturbo
the 1 i did was a 1.6 16v ztech, n i had a look yesterday n it doesnt have the top right pully itha
Old Apr 1, 2007 | 05:29 PM
p-38-king's Avatar
p-38-king
alright guys well i cudnt find the timing pin hole so i cud lock the crank up , so i put the number one piston at tdc and fitted it all back up and it seems the timinig is out , so i guess it has to be times a few degress past tdc does any one know which way tho is it advance or retard past tdc?? any help wud be good its a 1.8 zetec (black top) ina V reg mondeo thanks
Old Apr 2, 2007 | 06:56 PM
p-38-king's Avatar
p-38-king
well i guess no one knows
Billy_RS
16
Oct 11, 2025 09:41 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
robnock
Aug 22, 2015 10:51 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
