lean running when boosting
Old Mar 3, 2007 | 12:37 PM
Badman38's Avatar
Badman38
Default lean running when boosting
what causes a car to run lean and miss-fire when coming on boost i was at a rolling road shoot out today and my car was miss-firing badly. I have been suffering from a miss-fire for a while but could not for the life of me locate the problem . i thought it might be ignition related but i have tried a different coil pack, ht leads, and two sets of plugs. now it looks like a lack of fuel is causing my miss-fire.
my fuel pressure gauge is showing that the pump is funtioning properly any ideas what the problem could be ie fuel pressure regulator?
thanks in advance for any advice
sean
Old Mar 3, 2007 | 01:01 PM
Badman38's Avatar
Badman38
sorry a bit of the spec 2.0 zvh, 750cc injectors, s8 ecu,
Old Mar 3, 2007 | 01:09 PM
jon@work's Avatar
jon@work
what are the spark plug gaps set at ?
Old Mar 3, 2007 | 04:07 PM
Badman38's Avatar
Badman38
0.6 i thought it was the plugs but it definatly a lack of fuel causing the miss-fire
JK12
33
Apr 26, 2021 12:09 PM
dombanks
Sep 21, 2015 08:38 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
