is this chipped
Old Feb 25, 2007 | 12:44 PM
jx1117's Avatar
jx1117
Default is this chipped
Hello can someone tell me if this is chipped or not thanks for any help
Old Feb 25, 2007 | 01:14 PM
DazC's Avatar
DazC
That board is not standard so I would say yes.
Old Feb 25, 2007 | 01:16 PM
jx1117's Avatar
jx1117
how can i find out for def
Old Feb 25, 2007 | 01:21 PM
SafeChav's Avatar
SafeChav
Well thats definately not factory!
Looks like a PWM mod, i'd say it was!
Old Feb 25, 2007 | 01:44 PM
jx1117's Avatar
jx1117
sorry to be stupid but whats a pwm mod
Old Feb 25, 2007 | 02:08 PM
antony215's Avatar
antony215
Escort Rs Turbo
Pulse-width modulation stops the ecu boosting more than 8psi or so. Plus they do a few other things aswell i think
Old Feb 25, 2007 | 02:26 PM
Just a fancy term to describe what they all do.
It is not standard as there is no DIL there either, a socket that allows the use of plug in EPROM's(chips) as opposed to solderend ones.
Old Feb 25, 2007 | 02:55 PM
SafeChav's Avatar
SafeChav
No DIL? No Dual In-Line?
antony215, the PWM stops the ecu ever seeing more than 8 psi, the dizzy is used to set the maximum ignition advance on boost, crude but effective
Old Feb 25, 2007 | 03:16 PM
jx1117's Avatar
jx1117
so will it be ok to use on my rs i want to run a bar of boost will that be ok
Old Feb 25, 2007 | 03:46 PM
SafeChav's Avatar
SafeChav
As with most things on the RS, if you fit something like this you also get the plasure of visitng a tuner and parting with some more cash
Wouldnt advise fitting it without having it on a rolling road mate, otherwise it will be headgakset failure at the very bare minimum.
Old Feb 26, 2007 | 08:07 AM
jx1117's Avatar
jx1117
ok mate thanks for your help
Old Feb 26, 2007 | 12:38 PM
SafeChav's Avatar
SafeChav
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
RSmark84
Sep 13, 2015 01:29 PM
