Brake conversion question for Rally Guys esc cos
Gents
I want to scrap all the stupid ABS gimmickery and use a basic master cyclinder set up to run my braking
can some one possibly explain for me what i need to do and what typ of master cylinder to get etc etc
it would be very much appreciated.
thanks Glen
thanks Glen
1 Post
the one thing u should remember with the std cossie break setup.... it will allow the use of antilag as it does not rely on vacuum assistance form the plennum( which there will be none with a normal servo/master cylinder setup if running als. the electric pump will be fine. you can disconnect the 5 ABS sensors, and the abs ECU (in the boot) and you will have "normal" assisted breaking.
borboyous
22-08-2015 11:17 AM
saph in dorset
14-08-2015 10:10 AM
Red_bull
09-08-2015 08:34 AM
