Oil in my boost hose!
Just changed my SFS boost hoses for new Samco ones (less joins...less chance of leakage!! ) and found some oil in the hose that goes from the air box to the turbo inlet.
I get no smoke what so ever on startup or when boosting so i'm not too worried, just wondered if this was normal or if I have problem, cos i cant think where it would come from other than the turbo?!
Edited by webteam please see rules regarding selling on pf
section 10
https://passionford.com/forum/viewtopic.php?t=106240
Karlos
section 10
Karlos
The oil is probably entering the airbox through the breather system
If theres no oil in any other hose i wouldn't worry
Might be worthwhile uprating the breather system though, the oil will make that hose go soft and break down, and thats a very common hose to collapse when on boost, obviously because the turbo is sucking all that air through it
Originally Posted by SafeChav
"round black thing"
Karlos G
As said i wouldn't worrie about it to much if it's not alot as 90% of them have a bit of oil in the hose's just give the breather pipes a good clean out that will help
"round black thing"
A) Oil Control Filter
B) Round Black Thing
JK12
33
26-04-2021 01:09 PM
