ignition circuit
Old Jan 23, 2007 | 02:16 PM
davecosworth's Avatar
davecosworth
IM BACK
Default ignition circuit
how to wire up a ignition circuit on a mk 4 1.6 cvh non injection, lucus distributor
Old Jan 23, 2007 | 07:11 PM
davecosworth
IM BACK
i have the loom section that goes from the distributor to the coil and then to the fuel cut off solinoid that is on the carb just wondering what the wire from the multiplug has to be connected to i have a brown wire a green\brown wire a green wire and a black wire, the car has no loom in it at all so i just want to be able to wire it up to get it running as its only a hotrod
Old Jan 23, 2007 | 08:51 PM
SafeChav's Avatar
SafeChav
You seriously havin that many problems with it mate
Old Jan 23, 2007 | 11:45 PM
davecosworth
IM BACK
i no there is a negative and a positive but its just were the green\brown wire and green wire
Old Jan 26, 2007 | 07:46 AM
davecosworth
IM BACK
anyone
Old Jan 26, 2007 | 01:57 PM
SafeChav's Avatar
SafeChav
Shit sorry mate forgot to reply.
if i remember correctly, you have 3 wires
Black, Brown, and Green.
black = 12v ignition feed
brown = earth
Green = you'll need to disconnect the current green wire off the coil and connect this and this only to it.
You'll also have to bridge the fuel pump relay, as the pump won't run otherwise
Old Jan 28, 2007 | 05:17 PM
davecosworth
IM BACK
this is just for a normal 1.6 mk4 carbed escort lx mate i have the black the brown and the green and also a green and brown wire all these were in a multi plig down by the front cross menember
Old Jan 30, 2007 | 04:30 PM
davecosworth
IM BACK
anyone no what the green and brown wire is for, or anyone with a wiring diagram for a 1.6 escort mk4 estate
Old Jan 30, 2007 | 05:07 PM
SafeChav's Avatar
SafeChav
Ive posted above what you need to do?!
Old Jan 30, 2007 | 05:49 PM
davecosworth
IM BACK
is this the same for a non fuel injected tho just asking as you posted up about the fuel pump relay
Old Jan 30, 2007 | 07:06 PM
SafeChav's Avatar
SafeChav
I posted what you asked for.......... you have to bridge the fuel pump relay as its a tachometric relay and obviously won't be getting a signal.
Do exactly as ive posted above and it will work.......and for gods sake dont even spool the turbo up!
Old Jan 30, 2007 | 11:04 PM
davecosworth
IM BACK
safeChav
it isn't for the rs turbo mate its just for a standard 1.6 carbed escort estate on a f reg so it has a mechanical fuel pump that is driven off of the cam , the rs is being recovered back on wednesday
Old Jan 30, 2007 | 11:07 PM
SafeChav's Avatar
SafeChav
Ah fuck! lol..........where did i get that idea.
regardless then the wiring is the same, you'll also want to connect the green wire for the rev counter (on the assumption it has one) to the green on the coil, with a suppressor inline
Old Jan 30, 2007 | 11:26 PM
davecosworth
IM BACK
ok mate no worries i will give it ago, its just the green\brown wire that got me as i dont no were that one would go it was in the multi plug that was down by the inner wing that jioned this loom into the car loom
Old Jan 31, 2007 | 02:17 PM
SafeChav's Avatar
SafeChav
What wires have you got.
Old Feb 2, 2007 | 07:04 AM
davecosworth
IM BACK
right ok in the multi plug that is at the end of the loomdown by the inner wing on the head light there is a black wire i would say this is for 12V igntion feed, there is a brown wire which would be earth, there is a green wire which i would say went to the rev counter at some piont but were do i connect it now and the last wire is a green wire with a brown trace throw it were does this one go now
Old Feb 2, 2007 | 12:51 PM
SafeChav's Avatar
SafeChav
What year car is it off?
Old Feb 2, 2007 | 06:01 PM
davecosworth
IM BACK
its from a f reg 1988 mate
beller
Sep 21, 2015 04:13 AM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
steff19
Escort Range
Sep 9, 2015 10:14 PM
