3 door steering rack . help .
Old Dec 23, 2006 | 12:28 PM
rabmc's Avatar
rabmc
Default 3 door steering rack . help .
As above people , basically failed my mot on a rubber bush(circular) , not sure the exact name of it , but its located on the rod that comes from through bulkhead and down towards steering rack , sits right in the centre of this rod , and realy need to know the name of it just so i can order up a new item , also i take it this comes apart you dont need to change this rod as a whole ?
Cant seem to get it of , theres strange looking bolts with a patern on them going throgh holding this circular rubber in place , but really dont know what to use to get it off
Any help appreciated
Old Dec 23, 2006 | 04:30 PM
rapidcossie's Avatar
rapidcossie
nightmare rab!
these are like hens teeth to get...
i have done three now in my car(due to heat, now shileded)
best bet is trying gettin gonto anyone breaking a 3 dorr or 2wd saf..
i had to phone ALOT of people as they are unavail from ford at the moment
Old Dec 23, 2006 | 04:31 PM
jon@work's Avatar
jon@work
Steering coupling rubber - not available by itself from Ford. Whole couplings used to be available from Ford for about £90 - but no longer available.
GMS may be able to supply you with a rubber - you'll need to remove the coupling from the car, drill out the original "bolts" and replace with new rubber and nuts/bolts. They're on 0191 377 1718.
If they can't help, get yourself a 4x4 coupling, cut it shorter (in the middle of the coupling) and then get it welded up again . The added advantage of this is that the 4x4 couplings have a UJ on each end - no more rubber to perish.
Old Dec 23, 2006 | 05:10 PM
rabmc's Avatar
rabmc
Thanks people
Nothings ever easy
Sounds simple enough i suppose , but on closer inspection i lay stareing at it for 30 mins and thought ehh how do you get this off
Old Dec 23, 2006 | 05:14 PM
rapidcossie
it needs to be done from underneath mate..
get it on a ramp..
its not a hard job
mght need tracking done after it tho
Old Dec 23, 2006 | 05:18 PM
rabmc's Avatar
rabmc
I had it in the air in my street mate , and was underneath it , which is a bit of a regular sight now
Best bet just take the whole thing out and deal with it from there i think , take it its straight forward enough to take the whole "rod" as i call it out
When it gets changed iL try and protect it a bit more from the heat i think
cheers
Old Dec 23, 2006 | 05:21 PM
rapidcossie
its easy to get out i think mate as i have watched it been done now three times lol
maybe worth getting a 4x4 one and getting it modified..as thats what im getting when mine goes again
Old Dec 23, 2006 | 05:22 PM
rabmc's Avatar
rabmc
Cool
chowfornow
14
Jan 5, 2019 09:01 PM
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
Adam Graham
Sep 6, 2015 06:04 AM
