Removing Dump valve
Old Dec 18, 2006 | 11:25 AM
Dave_Hay's Avatar
Dave_Hay
Default Removing Dump valve
Bored of the noise already
on fiesta turbo......bit of bodged job into standard piping
can you still get that pipe from top of intercooler?
and the pipe from efi box - left hand side nearest water bottle and leading to dump valve.
where does this go if dump valve removed?
new to turbo ownership so be careful with me
anything to look out for after dump valves removed?
Old Dec 18, 2006 | 04:30 PM
SafeChav's Avatar
SafeChav
You can probably still get the pipe from Ford, or alternatively buy a set od Samco's
Are you talking about the small vacuum hose?
If its on a T piece to another pipe, remove the T piece and conect the pipes together. I know a lot of people use a spare connection on the inlet, if its on its own connection to the inlet just block it off
Old Dec 18, 2006 | 05:26 PM
Dave_Hay's Avatar
Dave_Hay
yeah small vacuum hose that goes to the top of aftermarket dump valve
ok to just block it off?
Old Dec 18, 2006 | 05:31 PM
SafeChav's Avatar
SafeChav
Yea as long as its not creating an air leak. Would look better if there wasnt a random hose there but will be fine.
Fudgey
Sep 17, 2015 01:06 PM
Si B
Sep 12, 2015 06:49 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
