4X4 SAPHIRE MISFIRE
Old Dec 31, 2003 | 01:52 PM
Default 4X4 SAPHIRE MISFIRE
HELLO IM NEW TO THIS BUT IT WAS RECOMENDED BY A MATE, AND SAID ITS QUITE HELPFUL
IM NOT SURE HOW THIS IS DONE BUT HERE WE GO
I OWN A 4X4 SAPHIRE COSWORTH WHICH IS RUNNING A STAGE 2 CONVERSION
IVE BEEN HAVING PROBLEMS WHERE THE REV COUNTER FLUCTUATES WHILST DRIVING WHICH CAUSES A JERK WHEN THE BOOST COMES IN
I HAVE TAKEN IT TO THE GARAGE WHERE PEOPLE WHO DONE THE CONVERSION ON IT. FIRST OF ALL THE HT LEADS WERE REPLACED, GROUP A IGNITION COIL, . THE COSY WAS RUNNING GOOD BUT 5-6 MONTHS TIME THE SAME PROBLEM HAS COME BACK. TAKEN IT BACK TO GARAGE AND THIS TIME THE IGNITION AMPLIFIER HAS BEEN REPLACED WITH A NEW ONE. COSY RUNNING GOOD. 5-6 MONTHS ITS SAME HAS BEFORE.
HAS ANYONE HAD A SIMILAR PROBLEM?
Old Dec 31, 2003 | 01:53 PM
HAPPY NEW YEAR TO ALLL
Old Dec 31, 2003 | 01:59 PM
Kevin B's Avatar
Kevin B
Mine was missing when I got it, new cap and rotor arm and problem sorted. Same problem under 1 year later and it turned out it had eaten the cap and rotor again... looks like it will be something that needs replacing every service lol
Mine has got the grp a coil aswell, dont know if that has anything to do with it.
The rev counter went haywire a while back too but that seems to have sorted itself out?
Old Dec 31, 2003 | 02:05 PM
RS500/364's Avatar
RS500/364
Phase sensor gave me almost the same problem
£15 is all it cost but SCC charged me £450 and i asked them to look at it first
Old Dec 31, 2003 | 02:21 PM
DazC's Avatar
DazC
I would say phase sensor....
Old Dec 31, 2003 | 02:44 PM
PJay's Avatar
PJay
Possible phase sensor and make sure it's a genuine cap and arm.
PJay
Old Dec 31, 2003 | 02:46 PM
Phil's Avatar
Phil
Jeebus
check the crank sensor doesnt have a loose connection either!
Old Jan 2, 2004 | 02:52 PM
Also when im starting the car sometimes there is a split second delay where theres no sound and then it starts up.
but ill look in to the replies i got thanks alot people
Old Jan 2, 2004 | 03:13 PM
Eagle's Avatar
Eagle
Super Moderator
yep ... very similar .. lacking power.. misfires like bitch on boost ...
fuel filter
Old Jan 2, 2004 | 03:18 PM
richm's Avatar
richm
Assuming the cap/rotor/leads and plugs are OK and gapped properly (try 0.6mm if they are appreciably bigger.. what plugs are you using?) then look into poor/intermittent connections:
1, check all connections to coil and ignition amplifier.
2, Check the condition of the three loom connectors on the bulkhead behind the engine, just above the cam cover.
3, Check/clean the loom earth tag connections on the inlet plenum cover - there are two earth tags with brown wires fitted under a couple of plenum chamber cover bolts, they must be clean and secure.
The tacho fluctuation (reading increases above where it should be, yeah?) is caused by interference getting onto the ignition amplifier trigger signal wire(s) - this is usually caused by poor condition HT components or bad earth connections to the ignition amplifer and associated loom.
Hope this helps.
Old Jan 2, 2004 | 03:26 PM
Eagle's Avatar
Eagle
Super Moderator
must say tho rich ... after i changed the fuel filter my rev fluctation just vanished
Old Jan 2, 2004 | 08:06 PM
richm's Avatar
richm
tacho fluctuation Pete?
Can only imagine it was HT generated interference due to bad burns or something..??
Old Jan 2, 2004 | 08:38 PM
Eagle's Avatar
Eagle
Super Moderator
yeah really got me goin.... checked all of the obvious... my mechanic said it sounds lean as i shot past him... so we changed it and foook me did it fly
Old Jan 2, 2004 | 10:14 PM
This is what it will be
mine had same problem and it was the loom connectors
Old Jan 4, 2004 | 11:17 AM
Eagle's Avatar
Eagle
Super Moderator
so... did ya sort it???
Old Jan 7, 2004 | 09:37 AM
[quote="Kevin B"]Mine was missing when I got it, new cap and rotor arm and problem sorted. Same problem under 1 year later and it turned out it had eaten the cap and rotor again... looks like it will be something that needs replacing every service lol
Just an idea but if your disributor was spinning slightly off center would this possibly cause early dizzy cap and rotor arm failure?
Old Jan 7, 2004 | 03:12 PM
ML's Avatar
ML
Are they genuine leads that were put back on the car?
Matt
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
