YB Engine to 2wd MT75 Gearbox?
Old Oct 30, 2006 | 06:34 PM
benduckworth's Avatar
benduckworth
Default YB Engine to 2wd MT75 Gearbox?
Can anybody help? I am fitting a yb engine (2wd yb red-top) into a westfield and am trying to bolt it to a 2wd mt 75 gearbox (as this is a really good installation and fits very well). The bell-housing will bolt to the block and the spigot/input shaft locates perfectly into the crank. However I have 2wd cosworth flywheel and clutch that generally looks like it should fit however when I offer up the engine to the box there is something adrift with the clutch operation as there does not seem to be any adjustment. Do i need to fit a 4wd flywheel or more likely do i need a mt75 4wd clutch operation arm and slider sleeve? Any ideas very welcome? ......please......
Old Oct 30, 2006 | 08:36 PM
CosKev3's Avatar
CosKev3
Pretty sure its the flywheel thats to big m8
Have read about this before,you have to machine flywheel down and fit a 2.0 DOHC sierra ring gear and starter motor
Thats assuming you are using the 2wd MT75 out of a 2.o DOHC sierra?????
Also how do you come off for space for the downpipe to fit past the clutch arm,cause its on the opposite side to the 4x4 MT75 and the 2wd T5 borg warner as used on YB sierras?????
Old Oct 31, 2006 | 10:56 AM
benduckworth
That sounds about right as I couldnt get the box to totally mate up to the engine with the flywheel on it, I had assumed that the bearing slider was fouling the preasure plate...??? So you think I need to machine the flywheel do you.... mmmm might it be easier to fit a T5 box and have to cut my chassis......??? Has anybody got any ideas...
Old Oct 31, 2006 | 01:30 PM
CosKev3's Avatar
CosKev3
Thats what I was told m8
Apparently not much of a job to machine the flywheel down though,worth finding out before you start cutting chassis
Not sure if you can get a 9 bolt flywheel in pinto size
Might be worth ringing Burtons and asking
Old Nov 1, 2006 | 08:56 AM
benduckworth
Then what about a starter motor....... I presume that the ohc starter will fit?
Old Nov 12, 2006 | 05:34 AM
msport's Avatar
msport
buy a broken mt75 4x4, pull off the 4x4 transferbox(rear half) bolt on the mt75 2wd gearkit and rear part. voila.. fits cosworth block and flywheel.
Old Nov 12, 2006 | 08:47 PM
Mr 19"'s Avatar
Mr 19"
As you can se in PF i have converted my 4x4 Cossie with the MT75 box. I just changed the front gearbox housing to the Cosworth housing and everything fits with the clutch and all. 2WD gearbox cradle and prop just bolts on there.
Old Nov 13, 2006 | 07:17 PM
CosKev3's Avatar
CosKev3
You make that sound easy,is it?????????
Have you done it yourself???????
What sort of power/torque will the MT75 handle in 2wd???????
Old Nov 14, 2006 | 07:02 AM
Mr 19"'s Avatar
Mr 19"
It took me and my friend about 5 hours to remove box, diff, driveshafts. The rest was an easy fit. Looks like standard inside with the right gearstick too! I run around 420-430bhp without problems. These boxes are not so week as many think. I ran 2,2 bar boost and 450 bhp through it but want to be on the safe side. You can see my car in PF October number. Mr Muscle feature.
Old Nov 14, 2006 | 10:26 AM
msport's Avatar
msport
Did this to my friends sapphy 4years ago when he blew his 2nd front diffenrential and the 4x4box 2nd gear broke. Easy as it sounds, no problem. He had about same power as mr 19" mentioned. 2.4bars 450ish, quite an improvement on highspeed acceleration with 2wd!
Old Nov 14, 2006 | 12:50 PM
CosKev3's Avatar
CosKev3
Were the boxes you used out of 2.0 DOHC Sierras????
Typical,missed buying Octobers issue
Old Nov 14, 2006 | 01:44 PM
msport's Avatar
msport
Originally Posted by CosKev3
Yes DOHC sierra 2wd mt75. Good thing, you can put a serious dogbox kit there too if you need to go fast.
SmudgerByName
52
Jul 28, 2016 06:14 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
