poly bush fitting
Old Aug 23, 2004 | 05:47 PM
moonstone mike's Avatar
moonstone mike
Default poly bush fitting
I need some advice on fitting poly bushes to the rear of my 3 door cosworth, has anybody done this mod ????? i done the fronts and was put off doing the rear due to people saying it was a nightmare to do??
ANYBODY HELP
Old Aug 23, 2004 | 09:12 PM
velocity's Avatar
velocity
it depends what way you want to do it i did my own on my saph (similar set up) and it wasnt that bad,the best way to do it is drop the complete rear beam with all the suspension, diff, shafts and brakes attached to it and then you can dissamble the componants in relative ease and reassemble them the same,the old bushes in the trailing arms if there original will require a press to push them out and they can be very tight the new polys are in 2 halfs and just push in the big donut polys that fit into the beam can be a bit of a to squeeze in and when u lift the complete assy in to position you will think that the bolts that go through the donuts are to short but they just about make a thread and then tighten them up until they stop,believe me thr donuts will compress even though its looks impossible,
i did all that myself a few months ago
best of luck
Old Aug 23, 2004 | 10:24 PM
moonstone mike
thanks for that mate........and thats the easy way
did you do it on the floor or did you have a ramp???
i take it trying to do it all in place is a nightmare,i got to do it as its like a boat at the mo......did it make much difference to the handling?
Old Aug 24, 2004 | 06:08 AM
pugo's Avatar
pugo
Default drop the beam
Velocity is right....!
Drop the beam, it is so much easier, the only ones that are a pig are the front beam mounts on the rear, i had to us plenty of soapy water and a hoooge vice to squeeze them in and again they look like you will never get the bolts in, however after a lot of swearing, scraped knuckles and thoughts of will it be worth it, they do go in!!!!!!!
I did mine on axle stands on the drive......and you will be suprised how quick you can drop the whole rear end!!!!
Pugo
Old Aug 24, 2004 | 09:58 AM
moonstone mike
Thanks for the replys lads.....im also going to be doing it on the drive with axle stands
How long shall i give myself to do the job there will be 2 of us doing it???
PLEASE TELL ME ITS WORTH ALL THE TROUBLE.
Old Aug 24, 2004 | 10:19 AM
pugo's Avatar
pugo
Default yes it is
yes its worth it, although it does firm it up quite a bit!!! (if that is what your after)
you will be shocked at how quick it comes out!!!!
remove rear wheels, take the exst off from d/pipe back, undo the 4 bolts that hold the back of the prop on, release h/brake cable pin and clip, undo lower rear shock bolts, release(after clamping)2 x upper brake hoses, unbolt rear a/r/b , unbolt diff mnt from floor , unbolt front beam mnts and your whole back end has just crashed to the floor(if you forgot to support it)
I changed all rear hoses (to aeroquip type) and renewed all rear b/lines while mine was off as they are a lot easier to do then(might be a thought)
I had mine all out , changed all bushes, renewed all rear lines and hoses, welded up the chassis rails with no other help apart from my 6 year old to hold brake pedal down when i bled them it took me all day and some of the evening, however i did have quite a bit of welding to do!!!
I reckon you could piss it in a morning with 2 of you and just changing the bushes!!!!
pugo
Old Aug 24, 2004 | 11:47 AM
moonstone mike
TOP MAN thanks a lot , i got to change the brake fluid so might do that along with the hoses.
Thing is gonna have to do it on the drive and with this sh*t weather we are having at the mo i want to know what i am doing and not sat in the wet under my car scratching my head.
Wilsfoci
15
Mar 30, 2016 10:26 PM
Oct 9, 2015 07:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
cameron2
Aug 10, 2015 12:14 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
