newbie help, just bought an RST
Hi people
just new to the site. I bought an RS Turbo last night.
However I have a problem with it. Runs good, smooth etc but when you open it full throttle is just closes down, if you hold the foot down it will hardly go over 1500 rpm, its like its on a VERY low rev limiter. it does it in any gear, its weird cause it runs sound apart from that - as I say, its only when its on FULL throttle
any suggestions would be mush appreciated
cheers
cheers
It's the hose from the metering head to the turbo thats going to be collapsing if this is the problem. They're always a bit kinked anyway cos its such a funny angle, and when the turbo starts sucking the air they collapse.
You could try putting a jubille clip in the middle of the hose to help retain its shape and take it for a test drive, if that makes sense?
sounds like it need setting up
maybe the throttle position senosr is not set up right?
maybe its over boost protection?
is it chipped?
what boost you running?
is it chipped?
its not chipped, tuned etc mate just running standard at the moment. Is there a way i can check the throttle position sensor myself?
also, how does over boot protection work? sorry im new to turbos, still doing alot of reading about them.
Its still the original amal valve etc so I dont think the boost has ever been tampered with
cheers for helping
Jamie
cheers for helping
Jamie
is it chipped?
is it chipped?
RodgeRS_Turbo, boost limit only happens when you are running 10/11psi of boost.
See if you can find a way to support the hose and see if it happens then, sounds exactly like it to me
cheers buddy, ill see about getting the hose supported etc tonight. in the meantime ill try and get ssome samcos or something ordered. will check for sale section etc. Ive also got a boost gauge im going to fit, as soon as I know how ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
I know its to tee into the plenum chamber, is that the thing on top of the inlet manifold thats got 2 hoses coming from it? my DV is tee'd into the right one, do i tee into the left for the boost? cheers
Samco's will never go a miss and they look pretty too
Boost gauges....easy
You will see a hose off the top of the plenum as you say, and it will run behind the heater box. Tee into that, and you will also find an un-used grommet in the bulkhead right by the hose aswell.
MAKE SURE you fasten the hoses to the t piece, cable ties would be ideal
![Content](https://passionford.com/forum/images/smilies/content.gif)
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
i got the gauge on, and seems to be running about standard (7psi)
can the fuel pump be causing this? the fuel pump i think is on its way ot, makes dodgy noises etc
i doubt it the fuel pump do make funny noises but they either make tyhe car run or not run ! so if your cars running then the pumps fine!
just go and have it set up m8 it will sort out all your problems!
Originally Posted by SafeChav
Does the boost pressure drop when you go to full throttle and the fault happens?
What about if you put your foot flat down before its spooled....will it cut out then, or only when the turbo is boosting?
SMILER258
28-09-2015 09:04 AM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
