s2 will not start help
Old Aug 13, 2006 | 02:49 PM
f411hur's Avatar
f411hur
Default s2 will not start help
sorry to trouble you all again but im going to burn this car if i dont get it going soon. .right here goes,recently changed the engine on my rs s2 connected everything back up as it should be car will not start no mater what i try,the fuel pump primes on ignition then carrys on running while your turning it over,ihave checked for air leaks,iv changed th distributor,both ecus there is fuel at the injectors so why wont it start ,so frustrating,i even towed the car today and still no joy,it is not even trying to start just turning over.any help would be much appreciated :wall
Old Aug 13, 2006 | 02:52 PM
SafeChav's Avatar
SafeChav
Have you tested for spark and fuel to the injectors?
Old Aug 13, 2006 | 02:57 PM
f411hur's Avatar
f411hur
Default s2
yes had spark plugs out turned it over and ther is a spark andthere is fuel getting there so ,just another thing at what position should the rotor arm be pointing when bottom pully is on tdc ,cheers
Old Aug 13, 2006 | 03:04 PM
SafeChav's Avatar
SafeChav
Check your firing order.
As you look at the cap the one in the 1 o'clock sort of position is number one, then go round the cap anti clockwise in the order 1,3,4,2
Old Aug 13, 2006 | 03:09 PM
f411hur's Avatar
f411hur
Default firing order s2
so number 1 is definatley in the one oclock position and not the 11 o clock position like mine is,sorry if this sounds stupid but i need to get the thing going
Old Aug 13, 2006 | 03:41 PM
SafeChav's Avatar
SafeChav
Yes thats correct.
I know and have also spoken to a number of people who have purchased some form of "RS Turbo technical data cd" from somewhere and its all wrong, which is about as much use as a cock flavoured lolly pop
Old Aug 13, 2006 | 03:49 PM
f411hur's Avatar
f411hur
right will try that tommorow,may get a bit more joy now,yes your right the book was bought of fle bay and obviously its a load of shite.thanks for your help AGAIN...
Old Aug 13, 2006 | 03:51 PM
SafeChav's Avatar
SafeChav
Again???
didn't realise i had helped before??
You'll get it sorted
Old Aug 13, 2006 | 04:34 PM
f411hur's Avatar
f411hur
Default rs2 sorted
ye was askin you the other day about the no spark story,any way that turned out to be the green wires infront of the rad that were broke,couldnt wait till tommorow just put plug leads were you said, started on the first click,how happy am i ? so thanks a lot dont know what id av done without this site cheers
Old Aug 13, 2006 | 04:36 PM
SafeChav's Avatar
SafeChav
You're more than welcome i know how annoying it is when things go wrong, just wish i had found this site about 5 years ago when i had to learn what i do now the hard way
Have fun
Old Aug 15, 2006 | 06:51 PM
HORNETS7's Avatar
HORNETS7
green wire in front of the rad in the loom are for the coil !
Old Aug 16, 2006 | 09:53 AM
SafeChav's Avatar
SafeChav
No too sure what you're getting at?
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
