FORD TRANSIT HELP!!
Old May 6, 2006 | 10:28 PM
FocusRS's Avatar
FocusRS
Default FORD TRANSIT HELP!!
Any ford mechanics out there able to help me? I have a 52 reg T280 transit van. For some reason the temp gauge goes straight up to red and then the engine cuts out to protect itself. As soon as it cuts out, the van is able to be started with the temp gauge back to normal. It then goes for about another minute or two and proceeds to do the same again. All coolant levels etc are perfect. I took the van to the garage and they replaced a heat sensor on the block but it is still doing it. Are there any more sensors? Any help is appreciated.
Old May 7, 2006 | 11:59 AM
DazC's Avatar
DazC
Is it a front wheel drive?
If so, they are notorious for the splines failing on the water pump and power steering pump. The camshaft has a pulley at the back of the head which drives a belt. This belt drives the PAS pump and the water pump is splined to the back of it so is driven by the PAS pump. The splines wear out and the water pump loses drive.
The cure is a new water pump AND power steering pump as they both lose their splines at the same time. Ford have a surcharge on the pumps so they want the old units back after they have been changed...
Old May 7, 2006 | 06:12 PM
FocusRS's Avatar
FocusRS
It is a front wheel drive version mate! Thanks for your help, I'll get it checked out.
Old May 7, 2006 | 07:03 PM
SafeChav's Avatar
SafeChav
Fairplay
Old May 7, 2006 | 10:02 PM
steve90spec's Avatar
steve90spec
the power steering pump is all steel , sorry but just done the water pump on my 260 swb 52 plate , it is true the ford pumps are crapy plastic and do fail , i never needed to change my pas pump as the female socket connetion that the water pump fits into when bolted together was steel, imo i would strip and inspect water pump and pas pump before ordering both parts , good luck
Old May 7, 2006 | 10:31 PM
FocusRS's Avatar
FocusRS
Just for future reference I found a ford transit forum and one guy has had the same bother as myself. It seems a wire was damaged for the temp sender. Going to have a good look tomorrow.
http://www.fordtransit.org/forum/
Old May 7, 2006 | 11:44 PM
SafeChav's Avatar
SafeChav
I was going to suggest a wiring short but DazC's post seemed very feasable. Let us know the fault
Old May 8, 2006 | 07:40 PM
DazC's Avatar
DazC
It could be wiring but I have had so many FWD Transits with this fault on the water pump PAS splines. It's a very common fault.
Old May 8, 2006 | 07:43 PM
DazC's Avatar
DazC
Both wear out. I can't recall ever seeing a plastic pump to be honest. The steel splines wears out inside the PAS pump as well as the steel splines on the water pump.
Old May 9, 2006 | 03:01 PM
FocusRS's Avatar
FocusRS
Daz C,
You are the man!!! Exactly what was wrong with mine! A wire was damaged too, but the water pump is goosed!
Thanks again
Dave
Old May 9, 2006 | 03:17 PM
SafeChav's Avatar
SafeChav
Originally Posted by FocusRS
Daz C,
Thanks again
Dave
He knows his shit
Old Apr 14, 2010 | 10:33 AM
showshine's Avatar
showshine
Hi all,
Found this thread via Google so thought i would bump it to save writing a new thread out.
I have a 53 transit and on the Mway last week the same thing happened to me as the OP.
I am a mobile detailer/valeter so my van is my toolbox and I am struggling to get this sorted.
Any ideas what this replacement pump will cost (So i can go to a garage armed with some info)
Many thanks
Old Mar 14, 2011 | 02:29 PM
droptopRST's Avatar
droptopRST
how do you remove the bottom right hand bolt, do you have to remove pas pump if so how do you get the slack on the belt ?
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Adam-M
Aug 27, 2015 08:55 AM
SteveyDee
Aug 25, 2015 07:48 PM
borboyous
Aug 22, 2015 11:17 AM
