sierra crank ps 18 cvh. can this be used to run on a l6 ecu?
as above i assume the 1800cvh sierra sensor can be used instead of the original cosworth sensor. I have machined the original pick up wheel down to 4 teeth and used the alloy crank sensor bracket(cover) as this looks factory.
dont know if the polarity is different between the 2 sensors but they both rely on breaks in the magnetic feild so i cant see them giving a different signal to the ecu?
awesome just fitted a 1800 cvh pully which was a tight fit had to take the engine mount off and jack the engine up just to fit the pully !and i have machined 3 mm off the pully edge.
i thought about doing that but got away with the sierra stuff as if you have a problem it is much more eaisily rectified!
why drill the block thought you just mod the f wheel to run the 4 pick ups rather than the ford trigger system?
odd
dont know if my block was from a frst now it has the cps hole and mounting hole or it may be a late rst block 90 spec ?
got an ofab loom if you need it Ł 30? name a price its yours.
Zoggon
10-08-2015 10:39 AM
